-   -   Do you think a tool running at 240v works better than at 120v? (http://www.diychatroom.com/f18/do-you-think-tool-running-240v-works-better-than-120v-47776/)
Piedmont 06-29-2009 09:29 PM
My brother and I had an interesting conversation, I purchased an old DeWalt radial arm saw wired for 240v and on the way home we got into discussing it can be wired/run at 120v as well. The motor says wired at 240v it draws 6.5 amps, if wired for 120v it draws 13 amps. The saw is wired for 240v from the factory.
On the long ride home came the discussion will the motor run better at 240v or 120v? Person A said 13 amps at 120v is the same as 6.5 amps at 240v they're the same and the motor will run the same. Person B said using 240v you have 2 opposite legs with push & pull and the motor runs better, why else does it come wired for 240v from the factory?
What's your thoughts or can you explain how different the motor will run wired either way? Thanks
HouseHelper 06-29-2009 09:39 PM
Person A is correct. Having it wired for 240V allows you to use smaller gauge wires.
jerryh3 06-29-2009 09:44 PM
Voltage drop is also less when wired at 240V.
Yoyizit 06-29-2009 09:51 PM
It won't make a noticeable difference. It might not make any difference at all. Power out = efficiency x power in.
Correction; I-squared-R loss will be 4x greater at 120v, so the efficiency is better at 240v. This is why cross-country xmission lines run at very high voltages.
adpanko 06-29-2009 09:55 PM
I don't know with technical certainty, but I don't believe it matters. I think it just gives you a second wiring option for machines that use up a lot of juice and won't fit on a 120v 15 or 20A circuit. So instead of having to wire a 120v 30A circuit, you can do a 240v 15A.
woodnthings 06-29-2009 10:11 PM
His post said:
Requires 13 amps at 120 volts, so for him a 15 amp circuit would work 14 ga, 20 amp 12 ga, is better. It's about wire size. It's cheaper to run smaller gauge wires than heavier gauge. I will always use the 220 v if given the option. Some tools require it, usually 3 hp or greater and have the thermal safety switch/voltage drop shut down. BUT... 220v breakers cost more and take up more slots in the panel. So, maybe it's a toss up on the cost?:huh: bill
220/221 06-29-2009 10:18 PM
Motor wil perform the same both ways.
13 amps is a good size draw and will require larger supply wiring then the 240 to run properly.
If it is to be used in the field, the 120 option would make more sense but you would need to use at least 12 gauge cord and try to plug into 20 amp circuits to be safe.
hayewe farm 06-29-2009 11:18 PM
The reason that high voltage is used for transmission lines is because the higher the voltage the lower the amperage the smaller the wire needed.
hayewe farm 06-29-2009 11:30 PM
Only if the same size wire is used and it would have to be a significant length to make a noticeable difference.
InPhase277 06-29-2009 11:49 PM
Being a guy who owns a table saw that can be wired for 120 or 240, I can say that it definitely works better on 240. It seems to get up to speed faster, and it runs cooler.
Also, I would think that since the current drawn at 240 V is less, there would be less self-inductance in the windings, which may be why it is able to start faster. But that's just speculation on my part.
And by the way, 120 V "pushes and pulls" with a hot and neutral just like 240 V does with two hots. Current flows to AND FROM a neutral just like any hot wire. The idea that the neutral is some kind of dead, limp stand-around is one of the most wide spread misconception about AC.
InPhase277 06-29-2009 11:51 PM
Riiiiiigggght..... Because of the IČR losses.
hayewe farm 06-30-2009 12:21 AM
Cost is the reason, I2R losses can be lessened with bigger wire lowering "R" or higher voltage lowering "I", it can also be lessened by lowering the frequency.
micromind 06-30-2009 01:41 AM
In theory it doesn't make any difference. In real life, any dual voltage motor will start quicker, have more power, and run cooler on the higher voltage.
Especially if it's a any distance from the source. Like more than 40'.
Rob
jerryh3 06-30-2009 05:18 AM
deleted.
Yoyizit 06-30-2009 01:47 PM
maybe he was thinking of. . .
http://en.wikipedia.org/wiki/Push-pull_amplifier
