Do You Tape Over Screw Terminals On Receptacles? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2014, 10:44 PM   #1
Rewards Points: 201
Do you tape over screw terminals on receptacles?
It seems like bad design to have exposed energized metal, even inside a box, given that the box has a bare ground conductor inside. Good workmanship would keep the ground conductor at the back, of course, but it's still awfully close proximity.
Yet the pros seem to look down on the practice of taping them over.
Run and find ou is offline   Reply With Quote
Old 07-14-2014, 05:07 AM   #2
DIY staff
Rewards Points: 7,174
Don't tape the recepticals --it makes future work rather hazardous---
This is the reason pros hate to see a taped receptical or switch---
Old 07-14-2014, 05:46 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
This is no reason to tape the screws, but you can if you so wish.
The Following 5 Users Say Thank You to stickboy1375 For This Useful Post:
garlicbreath (07-16-2014), jbfan (07-14-2014), Know A Little (07-14-2014), oh'mike (07-14-2014), Speedy Petey (07-14-2014)
Old 07-14-2014, 06:37 AM   #4
Rewards Points: 774
Typically a DIY'er would use cheap tape (though not always) and this makes for a gooey mess.
This is one of those personal preference things, and there is nothing wrong with it, but it has always been my opinion as a professional if I cannot install conductors and a receptacle in a box, I am most likely in the wrong profession.
Having said that there are times I might tape a receptacle such as in an old work box with Madison Straps.
Almost all the ones I have run across have the gooey mess or the tape was installed fairly tight and slips off over time.
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
micromind (07-14-2014)
Old 07-14-2014, 07:05 AM   #5
Rewards Points: 35
Rex Cauldwell's "Wiring a House" suggests to tape receptacles when they are installed in a metal box.
mprice214 is offline   Reply With Quote
Old 07-14-2014, 07:43 AM   #6
Rewards Points: 14,312
Only time I do it is when it's a metal box.
Even then I leave a twisted tab of tape where it's cut off so the next person can remove it easily.
One time one of my workers installed a GFI in a small metal box and did not take the time to center the outlet and it shorted out against the metal box.
It made a simple 10 min. job a nightmare to repair.
Gymschu (07-14-2014)
Old 07-14-2014, 08:19 AM   #7
First Home N00b
Rewards Points: 202
Same here. I calmed my fears by almost always using plastic boxes. In my current home, even all the wire nuts are taped. Gooey mess, and whenever I open up something I absolutely must go turn the breaker off and verify no power present at the outlet because I'm not sure what's underneath all the tape. Granted, you should do that every time, but I think we all know we take some shortcuts in the name of speed.
If you install outlets and receptacles properly, "close proximity" is not an issue. Just like if you strip back the insulation to code-approved length, you have no bare conductor exposed at the backside of the wire nut when you make your connections and therefore no risk.
95PGTTech is offline   Reply With Quote
Old 07-14-2014, 10:10 AM   #8
PoleCat's Avatar
Rewards Points: 1,652
That is actually a good time to get the tape out. If the outlet gets used on a regular basis for a vacuum it can work loose and make contact.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 07-14-2014, 10:47 AM   #9
Rewards Points: 4,796
The only time I tape is inside a metal box with a large receptacle such as GFCI or a dimmer. These come so close to the edge of the metal box that I'm not comfortable with it.
jeffnc is offline   Reply With Quote
Old 07-14-2014, 05:56 PM   #10
Rewards Points: 201
I'm very alert to making future work safe and easy.
What's the nature of the hazard?
Old 07-14-2014, 06:17 PM   #11
Licensed electrician
Rewards Points: 1,892
Since the device should be installed or removed with the power OFF there is no need for tape.
Old 07-14-2014, 07:52 PM   #12
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Tape not required
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-14-2014, 11:21 PM   #13
Rewards Points: 4,274
There are a few times I have pushed an outlet into the box, screwed it tight, and got a ZZZAAAPPP when hitting the breaker.
That pesky little UNINSULATED ground wire...
Bob Sanders is offline   Reply With Quote
Old 07-14-2014, 11:27 PM   #14
Rewards Points: 1,014
The three best, IBEW trained commercial electricians I know all tape the screw terminals.
Anti-wingnut is offline   Reply With Quote
Old 07-15-2014, 06:11 AM   #15
E2 Electrician
We all learn silly bad habits from our mentors....
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (07-15-2014), Know A Little (07-15-2014)
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 08:30 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
