Do They Make This Type Of Plug? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 05:56 PM   #1
Do they make this type of plug?
I need a standard 110v female plug that I can splice into an extension cord. Basically, I need to add outlets in the middle of the cord.
pomelo is offline   Reply With Quote
Old 10-13-2009, 05:57 PM   #2
Residential Contractor
Yikes, I don't think anyone here will want to touch that one without further information.
The do make extension cords with that type of set up, but depending on what you are using it for, it may not be a good idea.
rselectric1 is offline   Reply With Quote
Old 10-13-2009, 06:33 PM   #3
It is just to power led lights. They run at less than a 1/2 amp a piece.
Old 10-13-2009, 06:39 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Are you looking for some kind of vampire tap? Sounds unsafe.
What you could do, and I've actually seen this done by the maintenance guys at the hospital I work at, is to get a 3 gang box and run the wire to it, wire it then you have 6 plugs. I've been thinking of doing a large scale version of this at home for my computer equipment instead of having like 5 power bars. Lot of the items take up lot of space (adapters) so while I may have like 20 plugs does not mean I'm using them all. Basically a custom PDU. Make sure you use 12 or 14 awg extension cable with ground. May as well play it safe if it's being used in a permanent situation.
Old 10-13-2009, 06:47 PM   #5
I'm sure you can cobble something together that will work, and they definately make the kind of female receptacle I think you are talking about. However, safety should be of primary concern.
Anytime you break into a factory sealed extension cord, you must think of how the splices will be protected from weather, strain, etc. If this is for any type of permanant use, definately don't do it.
Old 10-13-2009, 06:48 PM   #6
I think some people do use lamp cord and snap type splicers for what I'm trying to do. I wanted to actually use an extension cord with some type of connector in the middle. I guess I'm looking for something more heavy duty than just a lamp cord with self tapping connectors. I don't want to use gang boxes because of the bulkiness.
Old 10-13-2009, 06:55 PM   #7
300zx's Avatar
Fire department
Hope you live close to a Fire department if you decide to rig up ext cords
300zx is offline   Reply With Quote
Old 10-13-2009, 06:55 PM   #8
They make heavy duty extension cords with several places along it's length that can be plugged into. I don't own one because I have never needed one (but have plugged into them many times on jobsites). I would guess that you could find one on line or possibly at a supply house.
That would be the way to go. All is safe and sound!
Old 10-13-2009, 06:58 PM   #9
300zx's Avatar
Post
Seen them also seems like lowes but maybe supply shop
Old 10-13-2009, 07:18 PM   #10
I buy lamp cord in 250-1000' spools & use vampire taps for my Christmas display
For Temp use only
I also have premade cords with triple taps along the length
And a premade heavy duty cord that has plugs along the length
Check the Christmas decorations area
Old 10-13-2009, 09:03 PM   #11
Electrician
For Temp use only
You may want to discuss this with your insurance company, I would almost guarantee if you have a fire that can be traced back to this wiring method they will not pay. Just sayin, CYA!
I would go the premade heavy duty cord route and toss the homemade zipcord contraption, JMO!
PS. electricity and/or fire doesn't know the difference between "temporary" and "permanent" wiring.
EBFD6 is offline   Reply With Quote
Old 10-14-2009, 04:25 AM   #12
GetYourShineBox's Avatar
lol..
GetYourShineBox is offline   Reply With Quote
Old 10-14-2009, 11:54 AM   #13
Rewards Points: 252
What Dave is using are UL listed for what he uses them for (temporary Christmas light display). They are fine and designed for this purpose. Thats what makes them acceptable. They are designed and UL approved for this application.
If it worked before you worked on it. You did something wrong.
Wrong plug? alpercata Electrical 6 12-30-2008 10:40 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
New cooking top on old 200V plug sahucd Electrical 3 08-24-2008 06:35 AM
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 05:28 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 01:27 PM
