#1 |
Do these work decently?
http://www.idealindustries.com/prodD...v=0&l1=push-in
Little plastic connectors that you just shove the wire into. I bought some years ago, but never used them; they just seemed like a novelty. But I have many trios of #12 to connect, and I have never gotten good at that. |
#2 |
They are primarily for use in situations where the connections are to be permanent....ie: not ever disconnected. I've used them within devices, control panels and other equipment but never in field wiring.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Semi-Pro Electro-Geek
For more than 3 wires, I think they're great. For 2 or 3, I think wire nuts are better.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice. |
#4 |
For 2 I wouldn't consider them; twisting two is easy. Even 3 #14 is easy; but it takes me 5 minutes to get a decent twist on 3 #12. So as long as they are sound and I already have them...
Thanks |
#5 |
Electrical Contractor
They kinda remind me of the idea of back stabbing a receptacle.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. |
#6 |
Yes they work.
I still prefer wirenuts. When they first came out, we had problems with them not holding well and wires would pop out resulting in troubleshooting a lot of connections. I say this because you said you bought some years ago. Newer ones have been much better |
#7 |
They have there uses.
I mainly use them for ballast change outs, and wiring that was cut too short in the box.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#8 |
What wire nuts are you using, and how? This sounds like a technique issue. 3 #12 under a yellow wire nut is pretty easy...
#9 |
My house was wired completely using those. They are VERY hard to pull out using pliers, so I wouldn't worry about any issues. Don't know about the older ones though. They also keep everything very neat in the box. I still use wire nuts.
#10 | |
Do these work decently?Quote:
With respect to wire nuts, if you get the kind with wings, you shouldn't have much problem tightening them down even with 12g wire. |
#11 |
Ive used thousands of these over hundreds of appartments without a single problem with one of these...i too prefer a wire nut, but these are easier, faster and there is less chance of a poor splice
My .02 cents |
| Display Modes | |
| Pulling permits -- getting caught on previous UN-permitted work and effect on taxes | jpfulton248 | General Discussion | 11 | 01-22-2013 04:58 PM |
| Neighbor's foundation work affect me? | Adam Poole | Building & Construction | 2 | 10-15-2010 01:02 PM |
| Contractor didn't start work in CT - What recourse do I have? | ControlTech | Off Topic | 3 | 09-28-2010 02:45 AM |
| grounding the workpiece you're welding | jarnold | Electrical | 41 | 09-08-2010 08:33 AM |
| Need help with permit/city got a Stop Work Order. | amdspitfire | General Discussion | 39 | 02-07-2008 03:45 PM |
