Do Smoke Detectors Need A Dedicated Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 09:43 PM   #1
Fiore is offline   Reply With Quote
Old 11-04-2011, 09:45 PM   #2
joed's Avatar
Rewards Points: 12,018
Post your location. In some area they are required to be on regularly used circuit (NOT dedicated to smokes)so that you will know if the breaker trips and to discourage you from turning off the breaker for nuisance tripping.
The Following User Says Thank You to joed For This Useful Post:
Fiore (11-04-2011)
Old 11-04-2011, 09:58 PM   #3
liscenced electrician
Rewards Points: 538
I always put them on the bedroom lighting circuit.
jimmy21 is offline   Reply With Quote
Old 11-04-2011, 10:19 PM   #4
Licensed electrician
Rewards Points: 1,284
As Joed said it depends where you are. In Delaware you would need a dedicated circuit.
Old 11-04-2011, 11:36 PM   #5
Electrician
Rewards Points: 780
So stupid and dangerous, if I lived there that would be one code rule that would be quickly violated in my house.
darren is offline   Reply With Quote
Old 11-05-2011, 04:50 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
To be more exact....I believe the typical wording is 'non switched' circuit. In other words, you can't turn it off except at the breaker.
But, then again....Delaware is one of those odd places.....
Old 11-05-2011, 06:14 AM   #7
Electrical Contractor
kbsparky's Avatar
In Delaware, you can't turn it off even at the breaker. They require a lock-on device to be installed before your final electrical will pass.
Of course, I've seen many homeowners remove that breaker lock, once they occupy the premises.
-KB
Old 11-05-2011, 12:12 PM   #8
Rewards Points: 538
And what if there is an overcurrent?
Old 11-05-2011, 12:52 PM   #9
Breaker locks do not prevent the internal mechanism from working. The lock would need to be removed and reinstalled after resetting the breaker. Given the load of a smoke alarm a trip from overcurrent is not an issue.
Old 11-05-2011, 01:27 PM   #10
Electrician
Rewards Points: 780
How many smoke detectors would it take to cause an overload, you would have two in everyone and a few outside before that happened. Wouldn't want to be in that house when the alarm went off, there would be no escaping the noise.
wiring smoke detectors lowcountry Electrical 4 06-21-2011 06:48 PM
Smoke Detectors for Bedroom cibula11 Electrical 4 09-14-2009 01:21 AM
Does a Dishwasher need it's own dedicated circuit? Casey_Oakland Electrical 46 02-22-2009 07:35 PM
Smoke Detectors / CO Detector Bocolo Electrical 9 02-17-2009 06:12 AM
Dedicated circuit for smoke detector? Randell Tarin Electrical 14 03-15-2008 12:07 PM
