Do Outdoor Receptacles Have To Be GFCI? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 02:10 PM   #1
Rewards Points: 135
Do Outdoor Receptacles Have to be GFCI?
Is it acceptable to have a non-GFCI receptacle in a weatherproof box located outside if the breaker it connects to is a GFCI breaker, or does the receptacle itself have to be GFCI type?
smata67 is offline   Reply With Quote
Old 06-01-2012, 02:12 PM   #2
kevinp22's Avatar
breaker is fine, its actually my preference to have outside receptacles on a gfci breaker or protected by a gfci inside the house. gfci receptacles physically outside seem to wear out faster
kevinp22 is offline   Reply With Quote
Old 06-01-2012, 02:22 PM   #3
Rewards Points: 794
I prefer breakers as well. Its gets confusing when there are additional receptacles downstream from a GFCI receptacle. You have to snoop all over the place to find the tripped GFCI. Also I just took three GFCI's out of my brothers new house since they were cascaded after GFCI's upstream of them.
If the GFCI breakers were priced a little lower people might be more inclined to use GFCI breakers instead of GFCI receptacles.
curiousB is offline   Reply With Quote
Old 06-01-2012, 03:43 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I prefer every outside outlet its own GFCI device, this way its an easy fix/reset for anyone.
Old 06-01-2012, 04:02 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Or you could do it like my in-laws house.....put the GFIC up in the 2-story bathroom and feed the outside receptical from it......
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
electures (06-02-2012), oh'mike (06-01-2012)
Old 06-01-2012, 04:41 PM   #6
kevinp22's Avatar
Cute set up - a code violation and inconvenient at the same time
Old 06-01-2012, 04:42 PM   #7
E2 Electrician
I like my house, GFCI breaker: feeds every bath and outside receptacle, that was allowable back in the day, and I tend to like it.
The Following User Says Thank You to stickboy1375 For This Useful Post:
gregzoll (06-01-2012)
Old 06-01-2012, 05:08 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
Not a code violation depending on the time it was done. Not sure of the NEC code year but it was compliant in 1978 (and maybe later). But definitely not convenient.
Coastal South Carolina
The Following 3 Users Say Thank You to rjniles For This Useful Post:
electures (06-02-2012), gregzoll (06-01-2012), oh'mike (06-01-2012)
Old 06-01-2012, 08:17 PM   #9
Rewards Points: 135
The panel is in the attic and I would need a ladder to get to it, does that change anything?
What if I sprung for the GFCI outlet (it would be for a 240V service, I've been unable to find one), which would trip first, the GFCI outlet or the GFCI breaker in the panel?
Old 06-01-2012, 08:28 PM   #10
Licensed electrician
Rewards Points: 1,474
There are no 240 volt GFI receptacles. GFI protection for 240 volt circuits is provided by a 2 pole GFI breaker.
Old 06-01-2012, 10:34 PM   #11
kevinp22's Avatar
[quote=smata67;934189]The panel is in the attic and I would need a ladder to get to it, does that change anything?
Wow, a panel you have to get a ladder to access. yikes. that opens a whole can of worms here I bet
There are times when gfci breakers and receptacles are best. I have all my outside rec (3) on a gfci 20amp breaker. the kitchen and baths are gfci receptacles as my wife was not going to the panel every time one trips. LOL - i installed them 6 months ago and not a single one has ever tripped.
Old 06-01-2012, 10:39 PM   #12
Rewards Points: 6,652
The only time that I would use a breaker, is if it is 1)Easily accessible, or 2) The branch circuit is a retro-fit, and it is hard to run electrical point to point to point, so that you can use one gfci outlet to protect the down line outlets.
Old 06-01-2012, 10:45 PM   #13
It is easier to use a GFI breaker than to try an fit a GFI receptacle into the old boxes on a two wire system. Also no need to find the first receptacle in the string.
Old 06-02-2012, 11:14 AM   #14
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Been there. Done that.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
