Old 11-07-2011, 07:03 PM   #1
Do newer dusk to dawn lights cover more area?
So, some roofers broke my mother's dusk to dawn light and I need to get her another. The problem is, it was made/installed back in 1985. It used a 175 watt metal halide bulb (or mercury vapor.. I can't exactly tell for sure.). Anyhow, all the newer dusk to dawn lights use either a 65 watt CFL bulb or a 100 watt metal halide. Do these newer light cover around the same amount of lighting area as the old 1985 lights? I've found one 175 watt mercury vapor fixture, but it's much bigger in diameter (15-18 inches for the new one vs 10-12 for the old one). Is there a way of knowing if the newer fixtures can cover more area with less wattage? Also, are the bulbs just as reliable? Do lumens determine the lighting area coverage? I just want to make things right for my mother. I also had a few other questions..
Can I use a higher wattage bulb in a lower watt fixture? What are the effects of that?
Also, can I use a metal halide bulb in a mercury vapor fixture or any other fixture (the 175 watt bulb bother have the wider diameter screw in base)?
Any contributions would be appreciated.
Thanks in advance.
Here are a few links to the dusk to dawn lights I'm looking at:
link1
link2
link3
link4
lighting is offline   Reply With Quote
Old 11-07-2011, 08:48 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
No, they are all the same. Just buy one that fits her budget and color choice and be done with it.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 11-07-2011, 11:46 PM   #3
Semi-Pro Electro-Geek
Mercury vapor is considerably less efficient than metal halide or sodium. Sodium is more efficient than metal halide, but not by much, and the yellow light is less attractive. CFL may be somewhat more efficient than the others, on par with sodium. Energy cost will greatly outweigh the cost of the fixture within a couple years, so I'd probably go with the most efficient and lowest wattage fixture available. That would be the CFL. Metal halide would be my next best choice. Do not buy a "new" mercury vapor fixture. As of 2008, the manufacture or importation of mercury vapor fixtures and ballasts is prohibited as an energy saving measure. Any mercury vapor fixture you buy now has been sitting around for awhile.
mpoulton is offline   Reply With Quote
Tags
dawn, dusk, light, lumen
Ground cover for unused area Subcooled Landscaping & Lawn Care 5 03-05-2011 03:29 AM
Advice for new patio area Mike2181 Landscaping & Lawn Care 2 07-19-2010 09:48 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
