Do My Range/oven Dials Function Like A 'dial' Lightswitch? (noob Question) - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 07:03 PM   #1
Do my range/oven dials function like a 'dial' lightswitch? (noob Question)
A 'dial' light switch has 'infinite' settings (maybe not infinite but a whole lot) as opposed to a standard switch which is either on or off. On my stove, if I set the dial to somewhere between the marked settings, does this have an effect or does it 'round' to the nearest marked setting? Same with the oven? Does this apply to most ranges/ovens? Is there a better term for what I'm asking?
Apologies if this is the wrong place to ask this.
(model: Estate)
3333 is offline   Reply With Quote
Old 11-18-2012, 07:23 PM   #2
Electrical Contractor
kbsparky's Avatar
Stove/oven controls are not the same as a dimmer for a light.
A lighting dimmer reduces the average voltage to the bulb, causing it to dim.
A stove/oven element control operates on a percentage basis, switching on and off to maintain a level of heat. For example: "High" would have it on 100% of the time.
Medium would be on 50% and off 50% of the time.
Low might be on 10% and off 90%.
While the control is "on" the element is applied with full power.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
3333 (11-20-2012)
Old 11-18-2012, 08:08 PM   #3
Thanks;
Seems like what you're saying is the element is either on/off (always on high), but the dial controls how long.
Does the specific dial setting still apply though? Okay it's not a constant, but the stove is still doing its best to maintain a certain %. Can I utilize 37% or 59% etc?
Old 11-18-2012, 08:46 PM   #4
Rewards Points: 83
Stoves with knobs typically run infinite controls with a bi-metal strip. Basically what happens is the current runs through the bi metal strip. As the strip heats it bends away from the point of contact. At a certain point it breaks contact and begins to cool. When it cools enough it makes the contact again.
They are called infinite controls or switches because they are infinitely variable.
Protocol. is offline   Reply With Quote
The Following User Says Thank You to Protocol. For This Useful Post:
3333 (11-20-2012)
Old 11-19-2012, 09:10 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
The light dimmer and stove control work exactly the same way, basically. It's called "pulse width modulation" which is a fancy term for "turning it on and off quickly". A standard light dimmer does this 120 times per second, and some fancy ones do it a few thousand times per second. This is fast enough that the light does not flicker visibly, because the filament doesn't heat and cool that fast and if it did our eyes couldn't perceive it anyway. Some high quality stove controls also cycle 120 times per second, using the same electronics as a light dimmer but heavier-duty. Any of them that say "solid state" or are for a ceramic or infrared cooktop work this way. Old fashioned or cheap ones cycle once every few seconds using a mechanical device instead. Since the stove element takes much longer than that to heat and cool, the heat level remains stable. As with a light dimmer, the control is infinite - there are no "steps" and the numbers are just for your convenience.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
3333 (11-20-2012)
Old 11-20-2012, 07:00 AM   #6
Rewards Points: 1,536
Ovens typically use a thermostat (separate element typically looking like a pencil with a string at one end) that cycles the power to the element: full on or full off.
Electric stove burners controlled by a continuous rotating knob, I think, have a constant voltage as set to any value by the knob position. How this is achieved (chopper elecronics?) I don't know.
And of course there are knobs with click stops. These are typically used with burners that have two or three elements, and different combinations of elements are energized by the knob positions, sometimes elements are in series with one another to give off different amounts of heat.
Specifically for chopper controls, the output is the same 60 Hz AC but instead of the full positive and negative sine wave loops, the waveform has much smaller loops of a different appearance. The loops are all the same size until you adjust the knob again. The "voltage" depends on the area under the loop if you draw the waveform as a graph.
The Following User Says Thank You to AllanJ For This Useful Post:
3333 (11-20-2012)
Old 11-20-2012, 02:06 PM   #7
Thanks everyone. I believe my question has been answered.
Noob question - how to fix splintered wood on interior door maxfischer Carpentry 14 11-02-2015 08:18 PM
Noob Question about framing walls lmholmes11 Building & Construction 15 06-13-2010 09:58 PM
re: paint noob question gramps416 Painting 8 12-07-2009 02:45 AM
potentiometers...dials...quick question. plzfl8me Electrical 10 07-09-2008 03:26 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
