Do I Need Uf Wire? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 12:23 AM   #16
DIYer
Originally Posted by oregondiy View Post
thanks to all for the answers.
What is AHJ and OP stand for?
AHJ is your inspector, in the NEC its called authority having jurisdiction. OP is original post.
Gigs is offline   Reply With Quote
Old 12-02-2008, 11:02 AM   #17
Rewards Points: 78
AHJ - Authority Having jurisdiction
OP - Original Poster.
I'm with inphase. NM is fine, but ugly. The porch ceiling is not wet or damp by any means (my interpretation). I would use EMT.
Old 12-02-2008, 09:45 PM   #18
Rewards Points: 260
Originally Posted by rgsgww View Post
I would go for uf, but you can go for romex if there is no way rain water can get to it.
Now if your local AHJ says you need conduit, do as they say.
I was just stating that conduit is required in areas where the wire could be damaged. I have never seen uf wire run exposed before. It has to be two feet under in my area. There has to be conduit coming up to its termination. I was just curious as to where uf wire is used where it gets wet and no conduit is required (other than underground).
bluefitness is offline   Reply With Quote
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
