Do I Need A Sub Panel Here? - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 01:27 PM   #61
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
JSM.
The panel I showed is called a "main lug" panel and is often used a sub-panel when a main disconnect is not required. Since you are in a out building you need a disconnect. To use as a disconnect panel (I will assume you use a 60 amp feeder):
Install a 60 amp breaker in the first 2 positions and connect you feeders to this breaker.
The breaker fill back feed power thru this breaker to the panel buss bars. Install your individual breakers in the other positions.
Coastal South Carolina
Old 04-23-2011, 06:30 PM   #62
Electrical Contractor
jbfan's Avatar
Rewards Points: 652
Originally Posted by rjniles View Post
JSM.
You also need a breaker hold down kit to fit that panel.
jbfan is online now   Reply With Quote
Old 04-23-2011, 06:44 PM   #63
Lost..
Rewards Points: 336
I still don't understand this main lug type panel.
If I use 2224 Aluminum service for my feeder from the main panel, is a 90amp breaker the biggest I can use at the main panel? I see 100 amp breakers, but I don't see any 90. I 'm sure they make them though. Would a 100amp breaker work, or is that too much for the 2224?
I'll pick up that panel that you guys recomended. I just want to be sure I get the right one before I redo the wall framing around it.
J S Machine is offline   Reply With Quote
Old 04-23-2011, 07:31 PM   #64
A "Handy Husband"
rjniles's Avatar
Here is a 90 amp breaker for $48
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
That is why my first recommendation was for a 100 amp Was http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
For $49 you get the panel, the 100 amp main breaker and 5 20 amp single pole breakers.
Old 04-23-2011, 09:51 PM   #65
Lost..
Rewards Points: 336
I took the other box back, and got one like recommended. They didn't have the one you all listed, but I got one like it that came with three 20amp skinny breakers. I got model # TLM812SCUD1K. It has 8 spaces and 16 circuits.
The only thing I don't understand is how it has a combined ground and neutral bar. I thought those were supposed to stay seperate. How is that supposed to work?
Old 04-23-2011, 09:59 PM   #66
Lost..
Rewards Points: 336
Here 's the inside of the new box
Old 04-23-2011, 10:01 PM   #67
jbfan's Avatar
Rewards Points: 652
You need to buy a ground bar kit to fit the panel.
Do not use the green screw that comes with the panel.
Old 04-23-2011, 10:18 PM   #68
Lost..
Rewards Points: 336
Ok I can pick up the ground bar.
So this box is good? I just want to be absolutely sure before I redo the framing.
Old 04-24-2011, 09:09 AM   #69
A "Handy Husband"
rjniles's Avatar
IMO Surface mount the box and don't worry about the framing. It will be easier to add circuits at a later date.
Old 04-24-2011, 09:20 AM   #70
Lost..
Rewards Points: 336
The walls on the inside of the shop are not going to be finished. No insulation, no sheetrock, no anything. I want to mount it inside the exposed studs because if I or the next homeowner want to finish it, they won't have to remove it and redo it.
Happy Easter folks
Old 04-24-2011, 07:35 PM   #71
Lost..
Rewards Points: 336
Here are some pictures of the mount. The distance between the studs is 10.5", and the box was 11.25"..
I notched out the stud on the left with a skill saw and a chisel-
Old 04-25-2011, 04:44 AM   #72
A "Handy Husband"
rjniles's Avatar
Since you compromised that stud I would sister another stud next to it.
Old 04-25-2011, 06:36 AM   #73
Lost..
Rewards Points: 336
That sounds like a good idea.
One of the other posters mentioned that I need to buy a ground bar kit for this panel.
I'm wondering how this is supposed to work.
I picked up a ground bar yesterday, but I want to first understand exactly how it is supposed to work. in the illustration I drew and from what I understand, the ground and neutral circuits must be kept seperate. Am I correct? It must be common for combine the ground and neutral circuits, because I have seen alot of people telling others that they must not do this..
From what I can tell, both bars are attached to the box, but are actually insulated form the box.. -My box does not have the ground bar yet (I will be adding it) but the neutral bar is attached as you can see in the picture I posted.
I would assume that it would not hurt for the ground bar to be in contact with the box, but then again I may be wrong. Can anybody clarify this?
Also, will a ground rod be required here? If so I will have to get the hammer drill and go ahead an drill the slab so I can get down into the earth.
Old 04-25-2011, 07:06 AM   #74
A "Handy Husband"
rjniles's Avatar
In a sub-panel the grounds and neutrals must be kept separate.
The neutral bar (right side of your picture) is connected to the neutral bar coming from your main panel. It is isolated from ground and the box itself.
Install the ground bar using the holes on the left side. It is connected to the box.
You need 2 ground rods installed outside, 6 feed apart. Bond the 2 rods together with #6AWG wire and connect to the ground bar with the same #6
Old 04-25-2011, 07:13 AM   #75
Lost..
Rewards Points: 336
Ok that clears that up. I figured it would be attached directly to the panel and in contact with it. I thought I would just drill the slab, and go down through the sill plate, but I suspect it won't hurt just to go through a wall right at the bottom and go outside of the building. I asume either way will work fine.
Panel cleanup gdoucette Electrical 5 06-26-2010 02:01 PM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
