Do I Need A New Box? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2008, 06:19 PM   #16
Rewards Points: 270
OK THANKS. I think it sounds like I should just get a new panel. Then we can separate anywhere they have 2 wires going into a single breaker into their own circuits and use all 1" breakers.
pcampbell is offline   Reply With Quote
Old 02-27-2008, 06:25 PM   #17
Rewards Points: 1,274
Exactly. The problem here probably started way back when the HO needed circuit # 13 added. It was probably for something irrelevant. You go to install a new circuit for a workshop, or an air conditioner, and find out you need and entire new panel or subpanel to do it... so in go the noncompliant piggybacks...
Seems people don't have an issue upgrading a panel or service when they're spending 20 grand on a kitchen, or pool... but not so keen when a 250.00 a/c requires a 2500.00 service change.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-11-2008, 10:23 AM   #18
Rewards Points: 270
Any ideas what I might expect to have a licensed electrician come in to put in a new box including the price of a new box?
Old 03-19-2008, 07:28 AM   #19
Rewards Points: 270
Is there a way to tell visibly the difference between a CTL breaker and a non CTL? I went to the depot and looked at them side by side and could not figure it out.
Old 04-11-2008, 04:06 PM   #20
Rewards Points: 270
What are your thoughts on running a sub panel rather than installing an entirely new panel.
Here is what I am looking at realistically. The kitchen will probably be the last additional circuits this house will ever need. I have 4 1" slots in the basement being used by electrical baseboard which I could remove because I have a direct vented space heater that will go in there.
If for some reason we remodel down the line, say in 8 years, I am not worried about throwing away $100 on a sub panel and a few breakers vs $2000 for upgrade to 200 amp + new panel (seems to be the going rate locally). BTW None of the local guys will replace only the box stating that we need more than 100 and that likely the feeders are in substandard condition.
Ahh I dunno.
Old 01-07-2009, 06:16 PM   #21
Rewards Points: 270
Originally Posted by Stubbie View Post
Yep, that is close enough. Don't forget the 20 amp branch circuit requirement for the minimum 2 small appliance circuits.
As for your question about 1/2 size can you clarify or post a picture of your panelboard. Murray to my knowledge has 'tandem breakers as shown below' designated MH-T but I am not aware of any 1/2'' breakers for a murray panel. Murray tandems are full size but two single pole breakers in one case. Does the old panel list the breakers it will accept? If the electrician installed a non ctl breaker meaning one that does not have the rejection feature so it can't be installed in a panel not rated for them he was incorrect in doing that.
Just a dumb qustion here.
If a breaker that has 12 regular sized breaker slots and allows tandems, but only has 12 spots for each neutral and ground, assuming it is against code to double up on neutral... how could I use the tandems without a code violation?
