Do I Need A Ground Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 04:16 PM   #1
Do I need a seperate grond rod? I have a water pump where the pipes go down 30 feet. Can I use the pipes as a grounding rod?
This is a house that sits at the edge of lake on very sandy soil. The wiring must be at least 50 years old, and I have upgraded many problems (like switches using the white wires). I do not trust that anything is to code right now. The service common looks like it is grounded at the pole, but I do not see any ground rod at the house.
Last edited by dcwestcott; 03-06-2009 at 04:35 PM. Reason: More details about the question.
dcwestcott is offline   Reply With Quote
Old 03-06-2009, 04:18 PM   #2
RippySkippy's Avatar
Need more information...is this a house, out building, what?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-06-2009, 04:46 PM   #3
Remodeling Contractor
you need a grounding rod and grounding conductor to the water pipe
Old 03-06-2009, 05:04 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
For newer codes, if the water pipe is metallic and in contact with the earth for 10' or more you must use it as the grounding electrode. This must also be supplemented by another electrode, typically a ground rod (or two).
There is no harm and only safety to gain if you add these to an existing older service.
Old 03-06-2009, 05:05 PM   #5
greengiant's Avatar
According to the current NEC, article 250, you need a grounding electrode. When we replaced the wiring in our house in 2007, our city required an 8' grounding electrode in addition to bonding to the cold water pipes.
greengiant is offline   Reply With Quote
Old 03-09-2009, 12:20 PM   #6
How about the Gas line?
Do I need to grond the gas line too. It comes from the city in a plastic line, so should I ground this also, just in case?
Old 03-09-2009, 12:27 PM   #7
Gas lines must be bonded, but this bond typically comes from the appliance circuit that the gas line is feeding.
Old 03-09-2009, 12:28 PM   #8
Rewards Points: 2,350
How are you planning on bonding a plastic pipe?
Old 03-09-2009, 04:51 PM   #9
Electrician
Rewards Points: 800
Why did you waste your time doing that, seeing a white on a switch is a very common occurance. They are useing the white(or should be) as your hot and the black as your return to your light. The NEC may require it to be reindetified the Canadian code says it does not have to be reindentified as long as the indetified conductor(white wire) is used as the hot wire.
darren is offline   Reply With Quote
Old 03-09-2009, 06:19 PM   #10
like petey said, the gas is to BONDED, but, not to be used as an electrode!.....they could have been switching the neutral
NolaTigaBait is offline   Reply With Quote
Old 04-07-2009, 04:39 PM   #11
Darren
Most of the cabin uses the metal clad flex conduit for the ground connections. Once, I was knocked off a latter while the wall switch was off and I touched the black wire while make a lamp change. Common or not, I think switching the white wire is very dangerous!!!!
Old 04-07-2009, 04:55 PM   #12
Rewards Points: 81
Switching the white wire can be done dangerously or safely.
If you are switching the neutral wire (so the hot goes to the light/outlet) this is very dangerous.
but if you use a switch leg (Is that the right term?) it is safe, see the diagram...
daxinarian is offline   Reply With Quote
Old 04-07-2009, 06:18 PM   #13
Rewards Points: 900
Darren
Always kill the power at the breaker. Never trust a wall switch to cut power!
FW
Ultrarunner2017 is offline   Reply With Quote
Old 04-07-2009, 06:45 PM   #14
Power can be routed to a light 1st, then the switch
As stated, you should verify power is off before touching/working on wires
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 10:14 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 08:41 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
