Do I Need To Ground A Pendant Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 03:35 PM   #1
Do I need to ground a pendant light?
I am hanging a pendant on SVT wire. The socket does not have a grounding terminal, so I bought 2 conductor wire thinking that it would work like a table lamp and not need an equipment ground. Before I commit to hanging it, I'd like to know why some light fixtures need a ground, but lamps do not. Also, do I need to buy new wire and find some clever way to ground the socket.
Mark
Rendulic is offline   Reply With Quote
Old 05-09-2009, 04:40 PM   #2
The grounding screw is usually on the mounting strap that gets attached to the box.
surrogate is offline   Reply With Quote
Old 05-09-2009, 04:50 PM   #3
Make sure the center lamp socket contact goes to the hot side of the circuit.
Old 05-09-2009, 11:12 PM   #4
I appreciate the response, but I'm afraid that I did not describe my question quite right.
If I hang a pendant light on 18 gage SVT wire is it ok to use a 2 conductor wire (black and white) or do I have to use 3 conductor wire (black, white, and green)
Mark
Old 05-10-2009, 12:10 PM   #5
Rewards Points: 204
Your plugging this lamp into an ungrounded receptacle right? And you bought lamp cord right? You have no ground right? Then you only need two wires. Right.
J. V. is online now   Reply With Quote
Old 05-10-2009, 01:17 PM   #6
It depends on the pendant light.
A glass pendant with no exposed metal parts near the socket, no problem.
220/221 is offline   Reply With Quote
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
