Do I Need A Ground From My Main To My Subpanel If I'm Using Aluminum Conduit? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 09:04 PM   #1
Do I need a ground from my main to my subpanel if I'm using aluminum conduit?
I am installing a 70A type subpanel in my dettached garage that will be fed from a 50A breaker in my main panel. Total distance is 71ft and Im running it underground. I heard if I use aluminum conduit from the main to the sub that I dont need to bring a ground from the main. Is this true? So all I need for my long cable run is #6 3 conductor for my 2 hots and one neutral?
ochoaj is offline   Reply With Quote
Old 10-07-2012, 09:13 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 484
That is true, but it would be cheaper to install pvc, and run a #10 wire for the ground.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
electures (10-07-2012)
Old 10-08-2012, 01:28 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
Even if you use AL conduit....do you really want to depend on the aluminum maintaining good continuity over the life of it?
PVC will be cheaper....but regardless of which one you use, run the ground wire....
I think it's poor practice to depend on conduit for earth ground.
Old 10-08-2012, 12:19 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
Aluminum conduit is perfectly fine as a grounding conductor. However, aluminum conduit doesn't do well underground in many soil types. Any degree of alkalinity can cause it to corrode away quickly. For underground, use PVC and a separate grounding conductor.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
brric (10-08-2012)
Shed subpanel BrandonD Electrical 21 10-14-2012 12:06 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 12:42 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
