Do I Need A GFCI On Sump Pump In Basement? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 09:24 PM   #1
Do I need a GFCI on sump pump in basement?
I have a sump pump in my basement that is used to pump out water from the washing machine. It is on a GFCI. I am worried that switch off while in use.
Craig1 is offline   Reply With Quote
Old 05-18-2011, 09:40 PM   #2
IBEW Electrician
No you do not need a gfci, I would recommend replacing it with a simplex receptacle, on a dedicated circuit!
Scott3229 is offline   Reply With Quote
Old 05-18-2011, 09:42 PM   #3
Licensed electrician
Rewards Points: 1,028
Under the 08 or newer NEC GFI protection is required for receptacles in unfinished basements and crawlspaces. The simplex receptacle exemption has been removed.
Old 05-18-2011, 09:46 PM   #4
IBEW Electrician
If his town/manici has adopted 08 code, ill personally run to your house right now and give you a big hug.
Old 05-18-2011, 11:29 PM   #5
Scared Electrician
Saturday Cowboy's Avatar
thats quite a marathon!!
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-19-2011, 05:21 AM   #6
Wonder what he would do if the 2011 had been adopted?
Old 05-19-2011, 05:57 AM   #7
dSilanskas's Avatar
Depends on where you live. If your going under the 2011 code yes you do need GFCI protection
dSilanskas is offline   Reply With Quote
Old 05-19-2011, 07:21 AM   #8
IBEW Electrician
lol
Old 05-19-2011, 11:01 AM   #9
My house was built in 08 with an unfinished basement. the outlets in the open area was a gfi. the outlet for the sump was not.
however when i was finishing my basement as a tem outlet i put the gfi on my sump and it would et it off when in use. i was lucky i cought this because my basket was 3/4 way full.
baum is offline   Reply With Quote
Old 05-19-2011, 01:14 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,858
The GFCI was tripping regularly when the pump operated? Holy crap! That indicates that the pump actually has a ground fault and is leaking current into the water. Modern GFCI's really don't trip without an actual ground fault. The only reason to avoid a GFCI on a sump pump circuit is if you have made a well-considered decision that flooding is more of a hazard than a ground fault. Personally, I would generally favor using a GFCI with some kind of power-off alarm to indicate a trip. If it trips, don't just reset it! There is an electrical problem to be solved.
Submersible pumps do fail, and when they do they leak current into the water. This can be exceedingly dangerous, especially if the pump still operates and gives no indication of a problem. This can electrify the outflow pipes and other metal objects near the sump, as well as the water itself. For me, the insurance of a GFCI on a sump pump is worth the small risk of pump failure. If you're in an area where a sump pump is really critical equipment, you should have a backup pump that doesn't rely on utility power anyway.
mpoulton is offline   Reply With Quote
Old 05-19-2011, 05:46 PM   #11
What specifically has changed? I have a refrigerator, washer and furnace in the basement all with dedicated circuits but no GFCI protection not to mention our dryer. hum.
whatrymes is offline   Reply With Quote
Old 05-20-2011, 07:41 AM   #12
DIY Enthusiast
I had a similar situation, but had a chest freezer plugged into the same outlet as the sump pump. I needed to plug in the charger for my battery backup (Basement Watchdog) sump pump, so I changed the single gang box into a dual gang box and added a GFCI on the first receptacle. The sump battery charger has a built-in alarm for power interruption so if the GFCI ever trips, the battery sounds the alarm and prevents my freezer from thawing.
Ed G is offline   Reply With Quote
Old 05-20-2011, 03:06 PM   #13
The electrical code changed. There used to be an exemption for single receptacles or receptacles in dedicated space behind appliances. This has been removed.
Old 05-20-2011, 04:53 PM   #14
Rewards Points: 506
Nec 210.8(A)(5)
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump Pump Recomendations - Zoeller vs Basement Watchdog vs..... alecmcmahon Plumbing 8 03-10-2011 08:51 PM
Sump Pump and GFCI Outlet sweetwaters Electrical 10 03-20-2010 07:01 PM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 07:28 AM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
