Do I Need A Fixture Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 09:01 PM   #1
Do I Need a Fixture Box?
I am replacing an old track light. When I took the old one down, I found there was no junction box, just this cable coming out of a wood beam on the wall. Do I need to install a junction box or should I just do it like the old one and stuff all the connectors into the cover that came with the track system? If I need a junction box, how do I install it in a wood beam?
patches101 is offline   Reply With Quote
Old 03-17-2013, 09:21 PM   #2
Rewards Points: 13,694
No box needs to be added.
Old 03-17-2013, 09:22 PM   #3
Master Electrician
Rewards Points: 3,864
If you use an end feed for the track no box is required. Floating(center) feeds require a j box.
brric is offline   Reply With Quote
Old 03-17-2013, 09:50 PM   #4
I am using a floating center feed. How would I put in a box since it is fed through a wooden beam?
Old 03-18-2013, 06:02 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Use a pancake box...
Ceiling light fixture wiring eveready Electrical 2 03-10-2013 10:55 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 11:19 AM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
