Do I Need A Dedicated Circuit??? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 02:44 PM   #1
Rewards Points: 150
Do I need a dedicated circuit???
Under NEC do I need to run a dedicated line for a 600 w wall mounted heater? The circuit only has 2 outlets on it now. Thanks
organick is offline   Reply With Quote
Old 12-13-2010, 02:53 PM   #2
Licensed electrician
Rewards Points: 1,632
Before that answer, what circuit are you thinking about adding this to? There may not be enough reserve capacity to add a 600 watt load to the existing circuit.
Old 12-13-2010, 03:11 PM   #3
Rewards Points: 150
the circuit has 2 other outlets on it. neither ever really get used. Its a laundry room. Not connected to washer circuit. Its a 15 amp circuit.
Old 12-14-2010, 06:57 AM   #4
Rewards Points: 150
Can anyone answer that??? Thought it was pretty simple one.
Old 12-14-2010, 07:56 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Yes. This circuit is not considered the laundry circuit.
jbfan is online now   Reply With Quote
Old 12-14-2010, 09:21 AM   #6
Rewards Points: 150
jbfan...what exactly does that mean?
jim... i was actually mistaken on the circuit. its a 20 amp gfci circuit with 3 outlets on it.
Old 12-14-2010, 10:11 AM   #7
jbfan's Avatar
Rewards Points: 490
Yes you can use it.
Old 12-14-2010, 07:11 PM   #8
Rewards Points: 150
Originally Posted by jbfan View Post
Yes you can use it.
Thank you..........Also with those wall mount heaters would a plug in style one meet code or do they need to be hardwired??
I greatly appreciate it.
Old 12-15-2010, 09:00 AM   #9
Rewards Points: 150
Yes you can use it.
JB....not to question you but I was just told by an inspector that it has to be on a dedicated circuit? Does NEC say that??
Old 12-15-2010, 12:08 PM   #10
jbfan's Avatar
Rewards Points: 490
Local codes will apply, but since it is not the laundry circuit, there is nothing I am aware of in the NEC that would not allow this.
You are talking about a device that will be used 3 months out of the year!
Old 12-15-2010, 12:56 PM   #11
In another forum this sounded like it might be the laundry circuit. Can;t be sure it is the same person.
http://www.nachi.org/forum/f19/dedicated-circuit-56291/
or this one
http://forums.mikeholt.com/showthread.php?t=132254
Old 12-15-2010, 01:56 PM   #12
jbfan's Avatar
Rewards Points: 490
or this one
I see he has changed the question a couple of times in the other forums.
Old 12-15-2010, 03:56 PM   #13
Rewards Points: 150
There is no changing of the question......Its all the same question.
I have a laundry room. it needs a heater. I have a 20 amp gfci that has 3 outlets on. I am putting a 500 watt heater in. That circuit is not the one with washer on it. The washer is on its own circuit.
Does the heater need to be on its own is all I want to know. Iguess I forgot to mention in one thread that it was a laundry room but its not on a circuit with the washer.
Thanks Guys
Old 12-15-2010, 08:09 PM   #14
Thank you for the clarification. With this not being the required laundry circuit you should be fine to add this load.
organick (12-16-2010)
Old 12-15-2010, 08:14 PM   #15
" Euro " electrician
frenchelectrican's Avatar
I will give you a short straight answer as long it is not used in landury circuit or sump pump circuit that is not a issue at all and with your 120 volt heater in unfinshed basement it have to be GFCI protected.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
dedicated circuit for table saw MeanGene Electrical 6 11-03-2010 08:31 PM
Planning circuit layout for barn tbeaulieu Electrical 8 04-08-2010 09:38 AM
Moving a Fridge, is a dedicated circuit required...or not? Snowy334 Electrical 7 07-03-2009 12:36 PM
Dedicated 20amp circuit chingon Electrical 1 03-31-2009 06:36 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
