Old 03-21-2009, 09:34 PM   #1
Do I need any special receptacles for the garage?
Was looking at receptacles at the box store this morning, and was wondering if there's any requirement or reason for buying the expensive ($5.00 each) heavy duty ones or are the regular "pro grade" (1.50) ok for the garage? I'll have a GFCI at the beginning of the circuit and then 8 or 9 scattered around in metallic boxes attached to emt.
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 03-21-2009, 09:47 PM   #2
dSilanskas's Avatar
As long as they are protected by GFCI you are fine. But depending on where you live you might need to get Tamper Resister receptacles. Most states require them now anyways.
dSilanskas is offline   Reply With Quote
Old 03-21-2009, 10:02 PM   #3
I would go with the heavy duty, you usually have a lot of plugging and unplugging in a garage or shop. "pro grade" is a miss leading label.
hayewe farm is offline   Reply With Quote
Old 03-21-2009, 10:06 PM   #4
Send a message via AIM to theatretch85
If you will be using these outlets frequently (plugging stuff in a lot) then the pro grade outlets will last longer and stand up better to the abuse. If these will just be used occasionally or for equipment that just stays plugged in (like a sprinkler system) then there would be no reason to go for the pro-grade. Most garages don't need the pro grade outlets, but if you forsee using these outlets a lot then you may want to think about getting the more expensive ones.
theatretch85 is offline   Reply With Quote
Old 03-22-2009, 12:48 PM   #5
J. V.'s Avatar
Correct. Most pros use the 0.39 cent ones.
Old 03-22-2009, 03:11 PM   #6
Just put a gfci in and feed the other receptacles with it.
About the receptacle...How about pick up a $1.50 and a 39cent and decide for yourself.
rgsgww is offline   Reply With Quote
Old 03-22-2009, 03:37 PM   #7
What, you don't get the 10% discount?
Old 03-23-2009, 01:22 PM   #8
J. V.'s Avatar
Nope. Pay the same as everyone else.
Old 03-23-2009, 04:09 PM   #9
My question is... what do the pros use in their own houses?
PirateKatz is offline   Reply With Quote
Old 03-23-2009, 04:29 PM   #10
my outlets are about 30 years old and i don't have gfi's in the kitchen and bath...nonetheless, i would use the cheapest outlets by leviton or cooper, ya know the .39 cent ones...that is what I would use in my own home
NolaTigaBait is offline   Reply With Quote
Old 03-23-2009, 04:39 PM   #11
I'm no pro but for my pc I use hospital grade plugs
Thats what us audiophiles do.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Garage Door Install marly General Discussion 2 11-17-2008 03:51 PM
