Do I Have A Neutral Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 10:57 PM   #1
Rewards Points: 308
Do I have a neutral wire?
I am trying to install a switch that requires a neural wire but I do not know how to identify whether I have the neutral or not. The box I am trying to install has five switches with several capped bundles of white wires. All the other boxes I have opened to compare only have one cord coming to the switch with white, black and ground.
The new switch is working but not receiving the X10 when I use the remote so this leads me to believe there may be a connection problem.
Please educate me on the neutral dilemma and how to identify. Thanks!
smokey847 is offline   Reply With Quote
Old 02-04-2012, 11:08 PM   #2
How many and what colors are the wires in the box? Any chance there are a couple white wires netted together in the box?
Knauer is offline   Reply With Quote
Old 02-04-2012, 11:24 PM   #3
Licensed electrician
Rewards Points: 1,048
You said you have several bundles of whites. Are you using the white that is in the same cable as the black you are trying to switch?
Old 02-04-2012, 11:33 PM   #4
Rewards Points: 6,652
My guess is, that the particular circuit they are trying to use, most likely is a "Switch Leg". Pictures and drawings help in this kind of situation vs. a generalization.
Old 02-04-2012, 11:35 PM   #5
Rewards Points: 308
This may make the process go quicker than me trying to explain. If you have any other questions about connections I am happy to answer. If it makes any difference, the switch I would want to replace is the one on the far left--controls outside floods. Thanks!
Old 02-04-2012, 11:40 PM   #6
Rewards Points: 308
On a side note, it looks like the power source's (wire to the electrical box) black is going to the switch on the far right and being piggy-backed through the switches, and the white is going to the right-side bundle of whites with the red cap. Hope this helps.
Old 02-04-2012, 11:45 PM   #7
Your pic shows 2 bundles of neutrals.
The white spliced to a black under the yellow wire nut is not a neutral.
gregzoll (02-04-2012)
Old 02-04-2012, 11:48 PM   #8
Rewards Points: 308
Right. So in order to connect my X10 switch, the neutral should be connected to either bundle?
Old 02-04-2012, 11:50 PM   #9
Connect it to the bundle of white from the same cable as the black on the switch.
Old 02-04-2012, 11:54 PM   #10
That could be a problem, especially since that white under the Yellow, is most likely a "Switch Leg". They are going to have to go to whatever light it is on, and confirm that.
Old 02-04-2012, 11:56 PM   #11
Rewards Points: 308
Are you saying connect it to the one from the line or the load? The line goes to one bundle and the load to another.
Old 02-05-2012, 12:02 AM   #12
Try to find the switch controlled black off the switch. In the same cable should be a white. Connect to it.
Old 02-05-2012, 12:45 AM   #13
Rewards Points: 308
I've been getting so frustrated with these X10 products. I am positive that I am connecting them correctly but still cannot get the signal across my power lines. Thanks for the help regardless!
Old 02-05-2012, 08:11 AM   #14
Rewards Points: 1,418
Is the X10 one of those systems that works on only half+ of the circuits in your home namely just circuits all on the same side of the 120/240 volt service?
You may not connect something to a neutral bundle none of whose wires came from the same cable as the hot wire you are hooking up*. Under some situations this will keep you from using that dimmer or other piece of equipment.
* This illustrates the problem (exception?) still found in ultramodern (post 2008 NEC) 3 way circuits where the two travelers are in one 2 conductor cable entering the switch box and an unswitched hot and neutral are in another 2 conductor cable (in lieu of 4 conductor cable) which is still done and this neutral is used to go with the two travelers.
+ Some remote control system make mention of a bridging device to allow control over both sides of the 120/240 volt service, which device does consume a watt or two of power 24/7.
Old 02-05-2012, 11:25 AM   #15
Missouri Bound's Avatar
Smokey...X10 Community Forum - Index Go here and get the help you need.
Do you want it your way or the right way?
breakers with multi wire branch circuit (shared neutral) corman Electrical 0 09-11-2011 12:52 AM
Neutral wire and Ground wire hooked together PIGEONS Electrical 4 11-16-2010 06:22 PM
my neighbor is using my neutral wire, is he stealing my electricty? stanlam Electrical 17 08-26-2009 08:45 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
