Do I Have An Electrical Issue? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 11:26 AM   #1
Do I have an electrical issue?
My readings are 124V to ground, and 213V between. This seems high to me for a 208V system.
Is this normal or do I have a problem?
HVACgirl is offline   Reply With Quote
Old 12-23-2009, 11:35 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
It shouldn't be a problem.
electures is offline   Reply With Quote
Old 12-23-2009, 02:46 PM   #3
208/(sq. rt. of 3) = 120v
100(213/208)=102% = 2% high.
For resi. power in MD, PoCo is allowed +/- 5%, and in some places they're allowed +/- 10%.
A 120v incand. bulb on 124v will last 60% of rated lifetime.
BTW, 124v x (sq. rt. of 3) = 215v vs. 213v that you measured. This is probably within a reasonable experimental error.
Old 12-23-2009, 04:17 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
where are you that you have 208 for line to line?
and no, the numbers you have are well within legally mandated standards if you do have a 120/208 service.
Now, if you had a 120/240 system like most of the homes in the US have, you would definitely be below any acceptable voltage readings on the line to line check.
Old 12-23-2009, 05:18 PM   #5
Rewards Points: 1,534
I would guess it is a commercial or mixed use building fed by a 3 phase 120/208 volt line where some tenants have just two phase lines coming into their premises.
Although most distribution systems are 3 phase, residential neighborhoods have single phase 120/240 service from a utility transformer connected to one distribution phase and ground or to two distribution phases (line to line), where between the latter the current is actually single phase.
Old 12-23-2009, 05:44 PM   #6
nap
You talking to me?
nap's Avatar
Being a professional commercial/industrial electrician myself, I am aware of the possibilities.
I was merely trying to determine if HVACgirl is a pro that is lost or truly a DIY'er.
Old 12-24-2009, 03:13 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Naw., you are ok with that voltage there.
It will varies a little depending on the system layout is.
It can run low as 200 volts and high as 218 volts { that is line to line voltage on 208 V system }
Merci,Marc
Electrical issue - 240V - Water Heater emoore Electrical 9 09-30-2009 01:45 PM
CSST Gas Line Lightning Strike and Electrical Issue duteberta Electrical 18 07-29-2009 05:01 PM
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 02:42 AM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 01:44 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
