Do I Have To Clamp? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 12:47 PM   #1
do I have to clamp?
I am rewiring our house and using the old outlet boxes. The internal clamps are a pain in the arse. Do I have to clamp the wires to the back of the box and if so why? How would they ever get dislodged down the road?
John
dogbone is offline   Reply With Quote
Old 01-10-2009, 01:11 PM   #2
Rewards Points: 2,350
The clamps keeps any movement of the cable limited so that abrasion doesn't wear the insulation through. If the clamp is a pain, just think how troublesome replacing the wire again is.
The cable must be clamped or else it needs to be secured within 8" of the box.
Old 01-10-2009, 01:47 PM   #3
Those are some good points.
Thanks inphase277.
Old 01-10-2009, 01:57 PM   #4
Yeah...if you live in a treehouse.
If you are using the old boxes, the clamps shouldn't be that hard to deal with. Take them out to give you more working room, install the cable and use a hold on screwdriver to re install them. The clamps will help to insure that the cables stay put while you are doing the wiring. You want about 1/2" of cable in the box. Not too much, not too little. The clamp will hold it in place for you.
220/221 is offline   Reply With Quote
Old 01-10-2009, 03:18 PM   #5
Remodeling Contractor
old boxes.. maybe BX... new wire is RMX.... so you need to modify the clamp. And yes you need the clamp. Code required. for safety. Silly people did not want to burn your house down,. And metal boxes need a clamp always. plastic boxes only if not stapled within 8"
Old 01-10-2009, 09:04 PM   #6
Good information everyone. I went back today and attached all the clamps. I feel much better...thank you > : )
Old 01-10-2009, 09:10 PM   #7
You mean... you don't?
Clamp Meter Findings jamiedolan Electrical 16 09-08-2008 09:13 PM
can I connect PB or Pex supply line to barb with clamp? grgryl Plumbing 11 08-20-2008 05:11 PM
Clamp Pipe to 2x4 virdicyer Plumbing 35 08-08-2008 10:53 PM
Can't Decide Wirsbo or SS Clamp Style PEX? twilightcall Plumbing 1 02-09-2008 10:11 AM
Clamp on Amp Tester Help stagger19 Electrical 3 03-07-2007 09:26 PM
