Hello everyone. I'm planning on running electricity to a 160 square foot shed and want to know if I have the capacity for what I'm planning on doing.
The house is a 1950s era construction (~1650 square feet including garage) that was recently renovated. The house was rewired with 3-wire copper; however, the investor didn't pull any permits for the work, so I'm not 100% confident all the work was done in a completely safe/code compliant manner.
The house has 125A 240V service with a matching breaker panel. Currently the following breakers are installed:
- 12 20A circuits for wall outlet power, fridge, microwave, heater (fan), dishwasher, and disposal.
- 3 15A lighting circuits
- 2 30A 240V circuits for the dryer and A/C
One item of note, for four of the 20A breakers two 2-pole 20A breakers are used. In both cases, each pole of the 2-pole breaker is allowed to be switched independently of the other. Is this safe? These are the breakers for the fridge plus a kitchen outlet, the microwave, and the heater fan. It seems to me, that if I had one of these breakers off, I could still be shocked while working on the "off" circuit by the neutral wire sinking the current from the other circuit on the 2-pole breaker.
I do think that several of the 20A outlet circuits are fairly lightly loaded. Two rooms of the house (4 bed room home) see little to no use.
Back to my question at hand, I want to have a 10,000 BTU A/C, three outlets, and lighting in my shed. I was thinking that I need a 15A and two 20A circuit (one for the A/C and one for the three outlets). The outlets in the shed will be used for running power tools and other utility appliances.
I plan to use direct burial cabling, probably three runs of 10/3, connected to GFCI breakers in the box. Flipping through the 2008 NEC, it seems that I can do this as long as I bury the wire a minimum of 12" in the earth. What should I use as conduit for the wire where it's above 12" of bury, i.e running from the box to the earth and from the earth to the entry on the shed? Plastic or metal?
I guess my main two questions are, are the three circuits (15, 20, and 20) correct for my uses and do I have enough capacity for adding these?
Sorry for rambeling on, but I appreciate any input.
