Do Ground Wires Require "green" Wire Nuts? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 11:14 AM   #1
Rewards Points: 77
Do ground wires require "green" wire nuts?
I know it would be good to use green wire nuts to connect ground wires, but is it required per code?
epeterson777 is offline   Reply With Quote
Old 03-14-2009, 11:17 AM   #2
Rewards Points: 168
No its not required.
Old 03-14-2009, 11:21 AM   #3
Rewards Points: 77
Awesome, thanks. I didn't think so. Time for me to go do some wiring.
Old 03-14-2009, 11:38 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Something is required, not just greenies.
Crimps and regular wire nuts are also fine, but you need something. Just twisting is not enough.
Old 03-14-2009, 11:49 AM   #5
Rewards Points: 77
Yeah, I know that. I have wire nuts, just not green ones. I didn't end up buying green ones since the quantities at the store far exceeded what I needed. So I'll be using red or yellow (depending on my wires sizes/number of wires).
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
Bare Ground Wires MrBill_DIY Electrical 4 10-05-2008 07:05 PM
hold the nuts! (wire nuts that is) analogmusicman Electrical 6 05-25-2008 11:34 AM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 02:32 PM
