Do 120v On Demand Water Heaters Need A New Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 04:17 PM   #1
Do 120v on demand water heaters need a new breaker?
I know large units require a 240v/30a breaker installed, do the small 120v on demand water heaters also require a new breaker or is it a typical small appliance wiring job?
Jimbo13 is offline   Reply With Quote
Old 09-22-2011, 04:26 PM   #2
Code05's Avatar
Rewards Points: 1,104
What do the instructions say?
Is it hard wired or cord connected?
What is the amperage?
Code05 is offline   Reply With Quote
Old 09-22-2011, 04:32 PM   #3
I haven't bought one yet, it's dependent on whether im going to have put a new breaker in.
Old 09-22-2011, 04:36 PM   #4
Missouri Bound's Avatar
Determine which unit you want to purchase and do the research by contacting the company's website. And as far as changing any breaker you need to be prepared to change the wire as well. You MUST match the circuits wiring amperage to the breaker amperage. Most spot water heaters require their own circuit.
Old 09-22-2011, 05:16 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I'm gonna say almost certainly yes.
Old 09-22-2011, 06:17 PM   #6
Code05's Avatar
I'm gonna say you are almost certainly right.
Old 09-22-2011, 07:04 PM   #7
Sparky
Rewards Points: 510
120v insta-hots suck anyway.
but yes it will almost definitely require its own dedicated circuit
Techy is offline   Reply With Quote
Sub-panel for 3 space heaters Daneel Electrical 15 05-12-2011 10:08 AM
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 10:51 AM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 11:53 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
