DIY Stove Tie-in For Movie Lights - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 09:09 AM   #31
Rewards Points: 812
Yes and if this is a "how to" to wire up lights for a grow-op UL compliance is the least of the OPs worries.
curiousB is online now   Reply With Quote
Old 06-15-2012, 11:28 AM   #32
Rewards Points: 83
Originally Posted by ionized View Post
There are no electrical code issues with what the OP proposed. The electric code and building official authority ends with the outlet.
UL, who cares, he is not selling anything.
Liability, OK, you better make it safe. He should be able to run 240V lights from this, no problem. As others have stated, the 120 loads is a bit dicy since there is no neutral.
In a 4-wire, there is neutral. He would just need to run a 4-wire "cord" instead of a regular 3-wire with the 4-wire plug. Ground would be hooked up to case, 120V loads would be hooked up to neutral, and both hots make 240V.
Protocol. is offline   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
