DIY Stove Tie-in For Movie Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 07:29 PM   #16
One light unit requires 110 to 130 Volts AC 50/60 Hertz; the other unit requires 220 to 240 Volts AC. Both on an earth grounded circuit.
It's funny because in the models I've seen on some movie sets, there's no breaker -- the wiring seems pretty direct, all in a single receptacle.
I've tried to find an example, attached is a picture that looks the closest (although this one seems old).
How do they do this? What are the trade-offs they have to deal with?
Thanks.
FCharles is offline   Reply With Quote
Old 06-13-2012, 07:31 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks.
That has got to be the most hacked picture I have ever seen!
Besides the HACK picture, what amperage are the loads you are trying to supply power to?
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (06-14-2012)
Old 06-13-2012, 07:57 PM   #18
Code05's Avatar
Rewards Points: 1,104
It is pretty FUBAR, Darwin would love it.
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
gregzoll (06-13-2012), jbfan (06-14-2012)
Old 06-13-2012, 08:02 PM   #19
Code05's Avatar
Thanks.
Sorry dude, there are a variety of solutions to your question, but you have yet to demonstrate that you are qualified, please seek out a licensed electrician. Harsh, I know, but that is my opinion.
The Following User Says Thank You to Code05 For This Useful Post:
stickboy1375 (06-13-2012)
Old 06-13-2012, 08:04 PM   #20
Code05's Avatar
Originally Posted by k_buz View Post
Sounds like someone is trying to wire up some grow lights to me.
At this point, I may be inclined to agree.
Old 06-13-2012, 08:34 PM   #21
Rewards Points: 1,418
Who was saying that a cord and (male) plug may not be hard wired into a portable subpanel but rather the subpanel requires a male receptacle that accepts an extension cord (perhaps with single female receptacle at one end)?
About the square portable outlet box pictured above with two duplex receptacles fed by a hard wired cord with plug, either it was homemade and not code compliant, or it has a 15 or 20 amp 120 volt plug at the other end. This box is no different from a common "power strip".
Old 06-13-2012, 08:56 PM   #22
Rewards Points: 6,652
Have to love the bootlegged ground.
Old 06-13-2012, 09:09 PM   #23
E2 Electrician
I think in this picture it's a bootlegged neutral.
Old 06-14-2012, 01:19 AM   #24
One reason that this sort of contraption is used on movie sets is because production companies have licensed electricians on hand to manufacture and maintain them. Another is that everyone who is allowed near them has signed the necessary legal paperwork to protect the studio if one of them blows up on a shoot and kills someone.
Evstarr is offline   Reply With Quote
Old 06-14-2012, 07:41 AM   #25
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I will give whoever made up those GFI's in the pic a little credit. This is the first time I've seen the devices match the phase colors.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (06-14-2012)
Old 06-14-2012, 07:33 PM   #26
dmxtothemax's Avatar
Rewards Points: 5,096
Hi -
I'm building a "stove tie-in" like the ones used on some movie sets.
It's a stove plug that wires into a double 110 receptacle/outlet (4 sockets).
The idea is to get more watts for lights easily when shooting in a house, by unplugging the stove and plugging this temporarily instead.
Models I've seen don't have a breaker as I presume overload risks are carefully monitored by film crew and the odd blown out light bulb isn't a big issue.
- 4 wires jut out of the stove plug: black, red, white and copper-color.
- These go into a double outlet receptacle
- The 2 outlets nested in it each have screws/plates on each side (silver and golden) and a green screw/plate .
- The receptacle has 1 green screw/plate
My questions:
1) Where to tie/screw in place the black, red, white and copper-color wires?
2) Do I have to wire nut/connect these to smaller caliber wires inside the receptacle before tying/screwing them in place on the outlets?
Charles
I understand what you want to do !
But to be safe the stove outlets do need to be 4 wire only.
You need two hots (usually the black and red)
You need a neutral (usually the white)
You need a ground (green or bare wire)
You will need 4 x 20a outlets,
You will also need 4 x 20a breakers (important)
As you cannot run 20a outlets off a 30 or 40a line
without some protection.
The black wire goes to two breakers and then to 2 x outlets.
The red wire goes to the other two breakers then to 2 x outlets.
Neutral and earth goes to all four outlets.
For extra safety consider using GFCI's.
This will work and safely.
But is it up to code ?
Depends on your locality.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
FCharles (06-16-2012)
Old 06-14-2012, 07:38 PM   #27
Thanks.
DO NOT USE THINGS LIKE THIS !!!!
Uses the earth for neatral !
No overload protection !
see picture in post 16.
Old 06-14-2012, 08:02 PM   #28
Semi-Pro Electro-Geek
Rewards Points: 2,858
I managed the rewiring of a physics research lab when I was an undergrad, and we specified red/green/blue receptacles for the three phases. It was really handy.
mpoulton is offline   Reply With Quote
Old 06-14-2012, 09:02 PM   #29
Rewards Points: 266
There are no electrical code issues with what the OP proposed. The electric code and building official authority ends with the outlet.
UL, who cares, he is not selling anything.
Liability, OK, you better make it safe. He should be able to run 240V lights from this, no problem. As others have stated, the 120 loads is a bit dicy since there is no neutral.
ionized is offline   Reply With Quote
Old 06-15-2012, 01:06 AM   #30
I tend to agree with this. Anything connected with a plug and not permanently installed is not bound by the NEC. However, the proposed device is definitely not safe.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
