DIY Stove Tie-in For Movie Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 05:29 PM   #1
DIY stove tie-in for movie lights
Hi -
I'm building a "stove tie-in" like the ones used on some movie sets.
It's a stove plug that wires into a double 110 receptacle/outlet (4 sockets).
The idea is to get more watts for lights easily when shooting in a house, by unplugging the stove and plugging this temporarily instead.
Models I've seen don't have a breaker as I presume overload risks are carefully monitored by film crew and the odd blown out light bulb isn't a big issue.
- 4 wires jut out of the stove plug: black, red, white and copper-color.
- These go into a double outlet receptacle
- The 2 outlets nested in it each have screws/plates on each side (silver and golden) and a green screw/plate .
- The receptacle has 1 green screw/plate
My questions:
1) Where to tie/screw in place the black, red, white and copper-color wires?
2) Do I have to wire nut/connect these to smaller caliber wires inside the receptacle before tying/screwing them in place on the outlets?
Charles
FCharles is offline   Reply With Quote
Old 06-12-2012, 05:39 PM   #2
Rewards Points: 6,652
1), it would only work if the circuit is a 4-wire, not 3-wire, and 2), you would need a panel for breakers, since you can not use a 30 amp circuit, unless the lights are rated for 30 amps, and usually they are 240volt lamps. You never stated if these lamps are 120volt or 240volt.
Old 06-12-2012, 05:40 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by FCharles View Post
Hi -
My questions:
Charles
This is a code violation if you are supplying 15 and 20 amp receptacles off a 40-50 amp circuit breaker...
Old 06-12-2012, 05:57 PM   #4
Electrician
Rewards Points: 794
Get yourself a small panel(4 or 8 space) and screw it to a piece of a plywood. Run a wire from the lugs in the panel to a male stove plug end, so when you plug it in the panel powers up.
Out of the panel install what ever plugs you need, use pipe nipples and it will keep it nice and clean looking.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
Missouri Bound (06-14-2012)
Old 06-12-2012, 07:01 PM   #5
I would use a 8 space square d panel, and build a smallish box with wheels to mount it to, then you can stash all the cords in the box, as at 40 amp they will be heavy
And don't cheap out on the plugs. I'm talking commrercial grade receps, metal covers , and nice "handy boxes"
It may be worthwhile to put in the odd 30 amp 120 v plug just in case someone has a really high power light.
You can buy a stove cord premade from home depot and direct wire it into the sub panel but it would be pretty short and it might be more convenient to build a longer one using portable cord.
sparkyjake is offline   Reply With Quote
Old 06-12-2012, 09:09 PM   #6
Code05's Avatar
Rewards Points: 1,104
Really?? The NEC does not think so...
400.7(B) Attachment Plugs. Where used as permitted in
400.7(A)(3), (A)(6), and (A)(8), each flexible cord shall be
equipped with an attachment plug and shall be energized
from a receptacle outlet.
Code05 is offline   Reply With Quote
Old 06-12-2012, 09:39 PM   #7
Sparky
Rewards Points: 510
If you read that, it says the cord shall have an attachment plug(cap), okay a premade cord has that, and shall be energized via a receptacle, the cord gets plugged in to a hot receptacle, so we're okay there too.
it does not say a cord shall have attachment plugs on both ends, or you'd never be allowed to use a cord that wasn't removable...
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
gregzoll (06-12-2012)
Old 06-12-2012, 09:59 PM   #8
Code05's Avatar
He said direct wire to a panel with a cord. No? I did not say you could not use a cord from a receptacle to a piece of equipment.
Old 06-12-2012, 10:03 PM   #9
E2 Electrician
I don't see where a panel falls under (A)(3),(6) or (8)
Old 06-12-2012, 10:09 PM   #10
Code05's Avatar
That is because it doesn't.
Old 06-12-2012, 10:09 PM   #11
E2 Electrician
I know...
Old 06-12-2012, 10:15 PM   #12
Code05's Avatar
I know...
I know you know, be quiet, I wanna see Techys response.
Old 06-12-2012, 10:54 PM   #13
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Sounds like someone is trying to wire up some grow lights to me.
Old 06-13-2012, 05:44 AM   #14
Sparky
Rewards Points: 510
Honestly I thought there was something in 590 that allowed it, but I agree you'll have to use an inlet and a double capped cord in this case.
Old 06-13-2012, 06:56 AM   #15
What I thought of, which may totally be wrong. Would to treat the panel as a stove, backfeed a 40 amp double pole and seperate the ground and whatnot.
Though that would be inconvenient as the box would be right beside the stove. Keep in mind you can get extension cords for stove plugs from your local RV shop.
I suppose you could use generator inlet if you want but I have not seen one in 40 amp
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
