DIY Replace Ballast? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 04:18 PM   #1
Rewards Points: 168
HI: I have 3 undercounter double bulb florescents (12in 8watt ea) on the same circuit. One of the fixtures is ok. The second and third have the problem.
On one, the bulb is very slow to light. On the second, on the opposite side of the fixture it does not light at all. The third works fine.
How do I change the ballasts in these? I tried pulling on them. NO good. I tried twisting them, no good. I tried pushing & twisting. NO good.
Is this a DIY deal? Is it worth repairing these or should I replace instead. They are about 12 yrs old.
Tx,
Tom
Sorry, I DID replace the bulbs. opps.
roztom is offline   Reply With Quote
Old 12-11-2009, 05:08 PM   #2
have you tried replacing the bulbs?
or switching the working one into the other fixtures.
smeric28 is offline   Reply With Quote
Old 12-11-2009, 05:12 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Honestly, instead of spending a lot of time and money on replacing ballasts and/or starters, sometimes it's more economical just to replace the fixture if you tried new tubes.
wirenut1110 is offline   Reply With Quote
Old 12-11-2009, 05:12 PM   #4
Rewards Points: 168
I did replace the bulbs. Sorry I forgot to mention this. tom
Old 12-11-2009, 05:15 PM   #5
Rewards Points: 168
Tx. They are hardwires. Is it just a simple pull out old and hook the wires up new with the twist nuts? There is BX coming out of the wall to the fixtures.
Tom
Old 12-11-2009, 06:13 PM   #6
Rewards Points: 510
Tom
yes, feel free to re-use the old twist nuts as long as they aren't dry rotted brittle,etc. In a lot of cases in just a little more cost effective just to replace the fixture if it's just a regular fixture.
Old 12-12-2009, 10:09 AM   #7
Rewards Points: 1,440
Do they have separate replaceable starters? Often it is the starter (the little "can" about 3/4 inch in diameter and 1-1/2 inches long you twist just a little and pull out) rather than the ballast that is bad.
Teh ballast (typically 6 x 2 x 1 rectangular for a fixture like this) must be matched to the fluorescent tubes. If the ballast goes, it's usually better to replace the whole fixture.
AllanJ is online now   Reply With Quote
T8 vs. T12 Ballasts capt2 Electrical 22 05-15-2010 04:25 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
Output on Florescent Ballast? aggiesrok Electrical 10 05-08-2009 04:09 PM
How do I replace a ballast? Beeter76 Electrical 7 07-22-2008 04:58 PM
please help w/ selection of bad ballast Mack V Electrical 8 10-17-2006 10:54 AM
