DIY Interlock For Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 08:14 PM   #1
Rewards Points: 322
DIY interlock for generator
I got inspired by this fellow
He avoided paying $150 for a $10 device from
http://www.interlockkit.com/typicalinstall1.htm
Though my panel is not the same, I'd like to design something like that. It seems to capture the spirit of DIY. I wonder if anyone here has made their own interlock / lockout mechanism and has some advice on it.
puttster
puttster is offline   Reply With Quote
The Following User Says Thank You to puttster For This Useful Post:
Kpack (12-20-2012)
Old 12-20-2012, 08:46 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
An interlock needs to be listed.
The Following 5 Users Say Thank You to k_buz For This Useful Post:
electures (12-21-2012), frenchelectrican (12-21-2012), Jim Port (12-20-2012), joecaption (12-20-2012), Speedy Petey (12-22-2012)
Old 12-21-2012, 08:30 AM   #3
Rewards Points: 322
Anyone got some ideas? Thanks!
Old 12-21-2012, 08:44 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes. You can't do it. The kit has to be UL listed. If you make your own, it is not listed and is a code violation.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 12-21-2012, 04:00 PM   #5
Rewards Points: 1,216
No good
It's a great diy scheme however I am sure somewhere, somehow, some date long ago someone already did this and probably isn't among the living anymore. Naturally or by accident.
As long as man has been alive people have tried to save a buck and lost their lives.
Don't mess with electric install an approved interlock or have one installed by a real electrician.
The codes are written for a reason so people don't die.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
dougp23 (12-23-2012)
Old 12-21-2012, 05:20 PM   #6
Oso954's Avatar
Rewards Points: 1,126
If it was just his life, maybe the objection wouldn't object be as great.
But, if his jury rig device fails to work properly and he back feeds the grid, he could kill one or more linemen. (Usually, the 120V becomes 12,000V when you back feed the first transformer)
Trying to save a few bucks for the approved and tested device is not worth the risk you are putting onto others.
Oso954 is offline   Reply With Quote
Old 12-21-2012, 05:50 PM   #7
Rewards Points: 1,298
The scary thing about that instalation is tha someone randomly drilled and put screws into that dead front. Part of the UL listing that approved devices get include the install instructions for the particular panel it is to be installed on. A homeowner engineered device like that could come in contact with the bus bars inside the box with less than favorable results.
danpik is offline   Reply With Quote
Old 12-21-2012, 06:03 PM   #8
Rewards Points: 322
Okay, watch the screws vs the bus bars? Now we're getting somewhere. Unbelievable the level of brain-deadedness here.
Old 12-21-2012, 06:17 PM   #9
Licensed electrician
Rewards Points: 1,634
What is unbelieveable is that you appear to have ignored numerous people that have told you that making your own interlock is in no way correct code-wise or liability-wise. I guess you are just one of those that keeps going until they get the answer they want.
Old 12-21-2012, 06:18 PM   #10
Special User
Rewards Points: 1,230
The code is there to protect human life. If you think saving lives is "brain-deadedness", there is nothing we can do to help you.
Just FYI. If you get the interlock kit made by your panel manufacturer, the cost is far lower than the interlockkit ones. The Square D QO2DTI, for example, retails for $28.39. So by the time you add up the labor and materials making an illegal interlock, it would be faster, cheaper, and easier to just buy the legal one.
Not to mention safer.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-21-2012, 07:32 PM   #11
Rewards Points: 322
I have a new Siemens panel, 150amp, series A, type 3R.
I wouldn't mind buying a lockout kit but can't find the one for my panel, though maybe it's just bacause I don't see one that suits my budget and eye.
Old 12-21-2012, 07:44 PM   #12
Could you please advise me where in the NEC that says the interlock has to be "listed" ? There is a lot of discussion going on in the "Electrician Talk" forum and everyone has a difference of opinion. If you know where it is "SO" stated, could you please share that article section? Thanks
khfactor is offline   Reply With Quote
Old 12-21-2012, 08:02 PM   #13
k_buz's Avatar
I'm over at that site quite a bit, and I don't remember a discussion about generator interlocks not being listed.
90.7 Examination of Equipment for Safety. For specific
items of equipment and materials referred to in this Code,
examinations for safety made under standard conditions
provide a basis for approval where the record is made generally
available through promulgation by organizations
properly equipped and qualified for experimental testing,
inspections of the run of goods at factories, and servicevalue
determination through field inspections. This avoids
the necessity for repetition of examinations by different
examiners, frequently with inadequate facilities for such
work, and the confusion that would result from conflicting
reports on the suitability of devices and materials examined
for a given purpose.
It is the intent of this Code that factory-installed internal
wiring or the construction of equipment need not be
inspected at the time of installation of the equipment, except
to detect alterations or damage, if the equipment has
been listed by a qualified electrical testing laboratory that is
recognized as having the facilities described in the preceding
paragraph and that requires suitability for installation in
accordance with this Code
Old 12-21-2012, 10:18 PM   #14
Rewards Points: 758
Puttster,
What is the complete model number of your panel. Siemens makes a variety of interocks for most of their lines.
I just put one on my Murray panel. It's VERY easy. Almost the same as installing any other 30 amp breaker.
For the curious, it also has a nice little UL sticker right on the interlock.
AandPDan is offline   Reply With Quote
Old 12-22-2012, 10:47 AM   #15
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
For a Siemens panel that new just look on the cover sticker. It will list the part number of the factory interlock.
You do not always have to spend $150 at interlockkit.com for one of these things.
Sorry if you think you cannot find "one that suits your budget or eye", but that is just how it goes. DO NOT diy hack something together.
I already get the impression that you are the type to do whatever you want regardless of the consequences so I'll just leave it at that.
Help trying to identify Main Panel circuit breaker Interlock solution Linos Electrical 9 05-16-2012 04:00 PM
Homebrew Generator Interlock Kelly62 Electrical 17 01-30-2012 11:13 PM
Interlock Kit for Generator db_9 Electrical 4 11-24-2011 12:20 PM
Question about QO interlock kit / breaker. speedster1 Electrical 8 02-04-2011 06:19 AM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 03:44 PM
