DIY Garage Spraybooth - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 09:15 AM   #1
I would like to build a spraybooth in my garage. What are the basics to keep in mind.
Akkerwillie is offline   Reply With Quote
Old 12-04-2011, 09:17 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Ummm.....ventilation?
Or do you mean electrically? If so then don't ask. Real spray booths are a classified location and require explosion proof wiring and fixtures.
Old 12-04-2011, 09:32 AM   #3
Garage Spraybooth
Thank you, but i did not mentioned that i am spraying woodglue with water base on to superwood. Will install blower in cealing with down blow trhrough small holes and the air will escape through n hole in the wall
Old 12-04-2011, 09:39 AM   #4
DIY staff
Rewards Points: 7,174
How big is the question---I have seen small ones for airbrush artists and ones large enough for automobiles---
What kind of sprayer? HVLP---airless?--high pressure air?
Old 12-04-2011, 10:07 AM   #5
Crusty Old Dude
Big Stud's Avatar
As long as you don't spray anything flammable throught it, any old fan and duct will do. If you want to spray anything else I'd get one that meets fire code requirements. Put a filter on it that can be changed either way.
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
The Following User Says Thank You to Big Stud For This Useful Post:
Akkerwillie (12-04-2011)
Old 12-04-2011, 10:57 AM   #6
garage spraybooth
Thanks........size of spraybooth will be50 m3 and i am using a 2bar pressure on my spray gun
Old 12-04-2011, 10:59 AM   #7
Rewards Points: 126
Install for the worst possible condition. Do not rely on the product you plan to use to build the booth. Build the booth to flammable standards. This way if your materials change, you are prepared for any new product.
The Following User Says Thank You to J. V. For This Useful Post:
Old 12-10-2011, 09:02 AM   #8
Spraubooth
After reading your reply again i gave the extracter fan a second thought. because i am spraying wood glue that sticks on the fan and duct and the driving motor will be damaged.Yes i can wash it off with hot water but the electic motor is in danger. So i think if i use a v-belt to drive the van then the motor is "safe" and not in the way of the glue. the "glued air" will pass through the fan and duct and the cleaning is easy. (quote) If i us a longer v-belt the motor can even be safer. (quot)
Old 12-10-2011, 10:53 AM   #9
Rewards Points: 126
I have seen the fans mounted remotely and the air is pulled through a filter or filters. I am no expert on paint booths, but I would imagine a filtration system would be the minimum requirement.
Akkerwillie (01-12-2012)
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
