DIY Electric For Remodel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2009, 02:04 PM   #1
Rewards Points: 768
DIY Electric for Remodel
We are converting our garage to a bathroom/bedroom and I was wondering about some electrical concerns that I have. Our garage currently has a subpanel of sorts which uses fuses. The rest of the house is on breakers. If I were to do the majority of the work myself (obviously keeping code in mind) would I need to replace the fuses with breakers or would that typically pass inspection.
The garage currently has 2 outlets and lighting with a switch and garage door opener. I'm guessing it would be a matter of rerunning romex to where we'd like it. (2-4 outlets in the room, 1 in bath and one light for the BR and Bathroom)
cibula11 is offline   Reply With Quote
Old 08-29-2009, 02:29 PM   #2
Electrical Contractor
kbsparky's Avatar
While the use of a fuse box and fuses is still recognized by the Code as valid wiring method, chances are that fuse box itself is not properly configured.
My guess would be that it does not have the ability of separating the neutral conductors from the grounds. Most old fuses boxes do not have this ability. You would have to check yours to see if it would qualify as a "sub-panel" before proceeding with using it. You would also have to ensure that type "S" fuses were utilized in order to be Code complaint.
That being said, it might be cost-effective to replace it with a small breaker box, with sufficient branch circuit capacity for your remodeling.
Care to take a nice high-resolution picture of that fuse box, and post it here?
-KB
Old 08-29-2009, 02:38 PM   #3
300zx's Avatar
Post
+1 need pic
300zx is offline   Reply With Quote
Old 08-29-2009, 02:57 PM   #4
zpm
yeah, right
Bedroom? Unless they make AFCI fuses, you'll need a breaker subpanel.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-31-2009, 06:21 PM   #5
Rewards Points: 768
Our building inspector did say that the room would require an AFCI. Does anyone know what something like this would cost to install a subpanel?? Only looking for ballpark figures here.
Old 09-13-2009, 08:52 PM   #6
Rewards Points: 768
What does something like this typically run?
Would somewhere between $1000-1500 be close?
Old 09-13-2009, 09:38 PM   #7
Prices vary widely by area & specifics of the job
No-one can give you an accurate estimate site unseen
Old 09-14-2009, 02:46 PM   #8
Rewards Points: 768
While I agree and understand that estimates can and do vary, I find it hard to believe that a general guess cannot be given.
Old 09-14-2009, 02:50 PM   #9
This site is for DIY projects, not cost estimates
Discussions of this matter are not what the site is about
Threads that enter into estimated costs are generally closed
A rough estimate? Anywhere from $200 sub only to $2k to hire out
Old 09-14-2009, 10:47 PM   #10
" Euro " electrician
frenchelectrican's Avatar
Scuba Dave is right on target with this info and there are too many variations to actally give out the estamae due unforesighted situation and other issue may arise and it do actally happened more than once from my experance.
Merci,Marc
Old 09-15-2009, 10:51 AM   #11
Rewards Points: 768
thanks....i guess
Old 09-15-2009, 12:32 PM   #12
Rewards Points: 80
Okay. Heres your price. $10,000.00 plus expenses.
Old 09-15-2009, 02:57 PM   #13
Rewards Points: 768
Thank you. Much appreciated. Plus expenses
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 09:34 AM
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 04:16 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 03:02 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 11:07 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
