Old 09-21-2012, 09:03 PM   #1
DIY 200amp set-up
I was talking earlier about the cost of an electrician doing this for me, but I really think that I can do most of the work myself. Pretty simple stuff. Question is about permits. In order to get the power turned back on, ( it is off now due to house being foreclosed on when I bought it) could an electrician pull a permit..check my work and sign off on it? Are most lic. electricians willing to do this?? I WANT and NEED it to be inspected prior to supplying house with power.
Savinmoney is offline   Reply With Quote
Old 09-21-2012, 09:12 PM   #2
Licensed electrician
DIY 200amp set-up
This is not legal in many areas. It also exposes the licensed contractor to additional liability for work they did not do.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (09-22-2012), Savinmoney (09-21-2012), Speedy Petey (09-21-2012)
Old 09-21-2012, 09:34 PM   #3
DIY 200amp set-up
A home owner can pull his own permit and do his own work in my area. Check in yours to see if this is allowed.
silversport is offline   Reply With Quote
The Following 2 Users Say Thank You to silversport For This Useful Post:
Old 09-21-2012, 09:37 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
DIY 200amp set-up
Both previous replies are dead on. More than likely you can just do it yourself and get it inspected.
NO WAY in hell I'd expose myself to that kind of liability with regard to a DIY job. I know most electricians worth their salt feel the same way.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (09-22-2012), Jim Port (09-21-2012), Savinmoney (09-21-2012)
Old 09-21-2012, 09:57 PM   #5
DIY 200amp set-up
I wouldn't want that liability either, just wasn't sure how to get the approval from the building inspector. Thanks for all the replies. Makes since to me to be able to pull your own permit and just get it inspected. That's what I wanted in the first place , but wasn't sure it was possable.
Old 09-21-2012, 10:52 PM   #6
Electrical Contractor
DIY 200amp set-up
If you feel you can do the work, pull a permit and then have it inspected.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
100amp service to 200amp service - double or single panel CapeCod153 Electrical 8 05-09-2012 09:03 PM
Upgrade to 200amp or Add a sub panel npaoline Electrical 8 12-20-2011 06:10 AM
100AMP to 200AMP childers2 Electrical 18 02-01-2011 09:19 PM
How would you determine if the wire running TO the box is 200amp? CoconutPete Electrical 12 04-30-2010 06:59 PM
Is it okay to run 4-0 cable 440ft with 200amp service panel jr67z Electrical 3 10-08-2009 09:49 PM
