Distance For Outlet Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 09:18 PM   #1
Distance for outlet question
So what i know is that you need an outlet every 12 feet and every 6 feet from a door or opening. unless the wall is less than 2 feet
question is do i measure and treat each wall as its own? or are they considered continuous if they bud up again one another?
example
i have a corner 90 degree. one wall on the corner is 11 feet the other is next to a door and is 2.5 feet.
If i place one outlet on the 11 foot wall about 3 feet from the 90 corner does that meet the requirement for both walls? i have less than 12 feet without a outlet and its within 6 feet of the opening to the outside on the short wall?
Or is the 11 foot wall its own and needs a plug, and the 2.5 foot wall is its own and needs a plug?
Thanks for the help you guys are great!
RobertDean is offline   Reply With Quote
Old 06-01-2012, 09:24 PM   #2
Licensed electrician
Rewards Points: 1,030
This might help you visualize things.
Old 06-02-2012, 12:49 AM   #3
Thats perfect thanks!!
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Distance of Conduit from Radiator / Heat Source jjohanson Electrical 4 05-12-2009 12:39 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
