Distance From Floor For Subpanel? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 10:15 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Distance from floor for subpanel?
I'm still tossing around the idea of putting in a sub panel to divide up the circuits a little better. It would be easiest to place it below the current main panel, but is there an elevation restriction?
Journeyman Plumber
Old 02-12-2012, 10:17 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Just a maximum height to center of breaker is all im aware of,How about just putting in 1 big panel?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-12-2012, 10:19 PM   #3
Licensed electrician
Rewards Points: 1,506
No minimum, just a 6'7" max to middle of the handle for the top breaker.
Old 02-12-2012, 10:24 PM   #4
Doing it myself
Alan's Avatar
I kinda thought about that, but I don't like the idea of trying to play with all that stuff myself. Then if the wires that are in there already end up being too short, i'm going to poop myself. (probably will anyway)
One of the big screws on the main wire coming in is looking kinda corroded, so it probably wouldn't really be a bad idea to do it. I just don't know if i'm up for it. I'd probably end up having the power off for a week trying to figure out how to get everything back in the way it goes.
Besides, I only have 13.5" of width where the panel is installed. I was just looking at subpanels at home bleepo and can't find any that narrow at all.
My wife wants me to watch some crappy movie with her now, so i'll check in on this again tomorrow.
Thanks for the input.
Journeyman Plumber
Old 02-13-2012, 12:24 AM   #5
liscenced electrician
Rewards Points: 538
under the main panel sounds very ghetto to me, but there isn't any code against it that im aware of. Much more common would be right next to it, with the tops of the two panels matching heigh
jimmy21 is offline   Reply With Quote
Old 02-13-2012, 08:59 AM   #6
Doing it myself
Alan's Avatar
That would have been the first place that I would have put it too.
Right side of panel = 5'-0 window
Left side of panel = meter base
I could put it on the opposite side of the garage I guess, but then we're talking a longer run of bigger cable.
Journeyman Plumber
Old 02-13-2012, 12:41 PM   #7
Rewards Points: 538
How about on the other side of the window or meter?
chimney distance from roof line abnormalnorman Building & Construction 7 11-14-2010 03:53 PM
Maximum distance of sink from drain? DIYHomeTheater Plumbing 0 06-14-2010 07:42 PM
Ground distance from water entry jprince Electrical 10 05-08-2009 05:27 PM
AC unit distance to out side compressor gene380 HVAC 4 06-28-2008 09:26 AM
siding distance from shingles? matchupeabody Roofing/Siding 13 11-01-2005 09:31 AM
