Distance For Electrical Outlet From Pond - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 07:48 AM   #1
Distance for electrical outlet from pond
What is the minimum distance that an electrical outlet has to be from a pond or water fountain?
richersa is offline   Reply With Quote
Old 08-02-2011, 03:07 PM   #2
seansy59's Avatar
Rewards Points: 252
I don't know about code, but I would definatly use common sense. Make sure it is GFCI protected, in conduit, weatherproof cover, wired/installed correctly, etc.
I would install it where you CAN NOT touch the water and the outlet at the same time. Maybe about 8'-10' feet away from water. This may be overkill, but I rather be safe then sorry. If you are using a pump for the pond, they usually come with really long cords, so you should be good.
seansy59 is offline   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
distance to a power outlet amakarevic Electrical 4 12-19-2008 07:57 PM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
