-   -   Distance for electrical outlet from pond (http://www.diychatroom.com/f18/distance-electrical-outlet-pond-112231/)
richersa 07-28-2011 06:48 AM
What is the minimum distance that an electrical outlet has to be from a pond or water fountain?
seansy59 08-02-2011 02:07 PM
14 Attachment(s)
I don't know about code, but I would definatly use common sense. Make sure it is GFCI protected, in conduit, weatherproof cover, wired/installed correctly, etc.
I would install it where you CAN NOT touch the water and the outlet at the same time. Maybe about 8'-10' feet away from water. This may be overkill, but I rather be safe then sorry. If you are using a pump for the pond, they usually come with really long cords, so you should be good.
