Distance Between Fire Sprinkler Head & Recessed Light - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 09:25 AM   #1
Is there a code that requires a minimum distance between fire sprinker head and recessed light?
Thank you for your help.
MartinD is offline   Reply With Quote
Old 09-26-2010, 02:13 PM   #2
NFPA 13 would be the reference needed for your question. Since you state its a concealed light fixture, I'm going to say there in no requirement. Location requirements come into play when a light fixture or other object can obstruct the spray pattern of the sprinkler. As long as the light fixture does not obstruct the sprinkler spray pattern, your fine. I would try to keep it a couple inches away for aesthetics.
if you have a light fixture that protrudes below the ceiling, it's a different ball game.
moopey is offline   Reply With Quote
Old 09-26-2010, 03:58 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I concur with moopey. While working as a commercial electrician, this type of question is often discussed. As moopey stated, since there is no concern with blocking the sprinkler, it should be a non-issue.
Recessed Light and Rain Shower head llevers Electrical 4 05-03-2010 11:26 AM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 07:39 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Recessed Light Installation theddy Electrical 1 08-31-2009 09:24 AM
Dual sensor Dual head motion light? sandyman720 Electrical 1 09-26-2007 07:40 PM
