Distance B/ween Buried Conduit And Water Supply Pipe - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 12:50 PM   #1
Rewards Points: 1,062
Question
distance b/ween buried conduit and water supply pipe
i am currently burying water supply pipe and electrical conduit 3 ft below grade to my upcoming shed. i was wondering if it matters what the distance is between the two? someone told me it has to be at least 6", which is what i barely have and they are side-by-side in parallel.
Old 07-26-2009, 01:24 PM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Better ask the building department what they want.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 07-26-2009, 04:40 PM   #3
I don't think so
I don't this is so. I think one has to be above the other and marked by identifying tapes 6" above each supply so if anyone digs the tapes will alert the digger to the lines below. Be safe! Go see you local building inspector. The rules may be different in many states and localities.
jehiatt is offline   Reply With Quote
Old 07-26-2009, 07:09 PM   #4
Question
does it matter at which depth it is buried, as long as it is deeper than the minimum? i am burying them both at the same depth, for convenience.
Old 07-27-2009, 12:30 AM   #5
Rewards Points: 284
In So Cal, the requirement reads, "No water or sewer pipes are allowed in the service trench. A minimum 12 inch horizontal separation of undisturbed soil is required between your service trench and any water, sewer or drain pipe", with "24 inch cover on private property."
Basically this says dig two trenches. Your area may be different.
tns1 is offline   Reply With Quote
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 10:20 AM
Any special considerations for burying PEX for water supply? Jim S. Plumbing 30 02-25-2010 08:00 AM
driving wire through buried conduit amakarevic Electrical 26 07-08-2009 07:48 PM
water coming up water supply liner candaneh Plumbing 3 03-30-2009 10:50 AM
Why is this? Ron The Plumber Electrical 11 02-28-2007 06:14 PM
