Disposal Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2008, 03:30 PM   #1
Disposal switch
I know that codes vary but I wonder if there is recommended distance from the sink for the disposal on/off switch. I have a designated 20amp circuit for this. Can I put a GFI outlet on this circuit also?
stan 41943 is offline   Reply With Quote
Old 03-28-2008, 03:32 PM   #2
Electrician
If that on/off switch is also the disconnect for the disposal than it must be within sight of the appliance... if not, then the switch can be anywhere... you can install it over the sink if you want...
You can install a GFI on that circuit, but that GFI cannot serve the countertop....
chris75 is offline   Reply With Quote
Old 03-28-2008, 04:48 PM   #3
Thanks Chris.
Old 03-28-2008, 05:13 PM   #4
Electrician
Thanks Chris.
no prob...
Old 03-28-2008, 05:23 PM   #5
Git
Have you seen these air activated switches?
You can mount the button right next to the faucet or somewhere close by and then run the air line down to the switch which gets plugged into the outlet where you plug in the disposal.
Just a thought
Git is offline   Reply With Quote
Old 03-29-2008, 06:41 AM   #6
How cool! Get to put in my GFI for an air activated switch. Now maybe my wife will be impressed. Thanks Git.
Old 03-29-2008, 07:36 AM   #7
Electrician
I wouldn't waste my money on a GFCI... the only receptacles in a kitchen that require to be GFCI protected are the ones that actually serve the counter top...
Old 03-29-2008, 06:17 PM   #8
I believe I've got it!
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 10:18 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
