Disposal Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 02:39 PM   #16
disposal outlet
Well I've checked the circuits at the panel,all read 119-120,Dbl's at 248. Also went through the breakers room by room again(re-labeled when I moved in) everything matches,but I do have 1-240 and and 1-120 that I couldn't find what they go too. I have the old labeling and it stats the disposal is on 5 but that is not correct.
Could there be a grounding issue? never heard of that causing an outlet not to work but I don't know?
Livonia38 is offline   Reply With Quote
Old 07-22-2012, 02:54 PM   #17
Disposal outlet
Ok, checked all the breakers at panel,all read 119-120 and 4 at 250,I went through room by room and it matches the panel labeling,of course there's no disposal on the label. Any other steps you can recommend?
Old 07-22-2012, 05:42 PM   #18
Master Electrician
Have you checked to see if its the receptacle that's bad?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-22-2012, 05:50 PM   #19
disposal outlet
Is that the same as outlet? if so I changed to old switch and outlet with new ones.
Old 07-22-2012, 07:39 PM   #20
Master Electrician
next step is to check the line for a short somewhere, disconnect the power and start testing for an open wire somewhere.
Old 07-22-2012, 10:27 PM   #21
"So I Re-Wired It"
MisterZ's Avatar
Depending on the age of the home, there may be a few junction boxes. Hopefully they are all accessable as they should be.
Good luck friend
MisterZ is offline   Reply With Quote
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
