Disposal GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 10:20 PM   #1
Disposal GFCI
Just checking on if the disposal outlet under the kitchen sink needs to be GFCI protected? I have seen several that are direct connected (via a pigtail of sorts), but my disposal will actually plug into a recep. So the question is if this recep needs to be a GFCI recep?
DaveHembree is offline   Reply With Quote
Old 10-23-2007, 07:49 AM   #2
Licensed Pro
There is no NEC requirement that this receptacle be GFCI protected.
Old 10-23-2007, 01:21 PM   #3
NEC 2005 210.8(A)(6) (current issue used by most states)
Many countertop kitchen appliances are ungrounded, and the presence of water and grounded surfaces contributes to a hazardous environment, leading to the requirement in 210.8(A)(6) for GFCI protection around a kitchen sink. The requirement is intended for receptacles serving the countertop. Receptacles installed for disposals, dishwashers, and trash compactors are not required to be protected by GFCIs.
You're good to go.
ChristopherSprks is offline   Reply With Quote
Old 10-23-2007, 01:30 PM   #4
Thank you for the responses! I really appreciate the quick replys!
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
GFCI protection for Shop/Garage Sub-Panel porterpearl Electrical 3 01-06-2006 03:33 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
GFCI problem Unregistered Electrical 3 02-08-2004 09:41 PM
