Dishwashing Liquid As Wire Lubricant? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 10:28 AM   #1
Rewards Points: 91
dishwashing liquid as wire lubricant?
is it safe to lubricate wire with dish soap when pulling it through conduit? seems like it is mild enough
debiasio is offline   Reply With Quote
Old 09-03-2010, 11:10 AM   #2
Just call me Andrew
Rewards Points: 1,020
They make wire lubricant....I'd go get some of that, it's cheap.
Who knows (maybe someone here?) if soap deteriorates insulation on wires. Since they make a product intended for exactly what you are doing...seems simple to me
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
Speedy Petey (09-03-2010)
Old 09-03-2010, 11:30 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
+1
Old 09-03-2010, 11:45 AM   #4
joed's Avatar
Rewards Points: 12,878
Since it is not rated for wire pulling you could technically get rejected by the inspector if he knew about it. Dish soap has not been tested for its effects on wire insulation.
Old 09-03-2010, 10:53 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Many big box store will have wire lube bottle to use to help you to pull the conductors much easier.
They will be in electrical area so you can't miss them and they are only couple Euros so if you have pretty long run grab couple of them.
I go thru a bit of wire lube when I pull much larger conductors the last big job I have work on I allready use over 20 Liter worth of it { 5 gallons }
I know it will be messy if not carefull and have plenty paper towel or clean cloth rags to wipe it off when you get done.
Oh yeah DO NOT use the dish soap they are not really slippery at all.
Merci.
Marc
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 11:41 AM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
