-   -   Dishwasher wiring (http://www.diychatroom.com/f18/dishwasher-wiring-119129/)
tcarter 10-03-2011 02:12 PM
Dishwasher wiring
I want to install a dishwasher in an older kitchen that has never had one. Currently I have a direct wired disposal under the sink that I was going use the power from to run to the dishwasher. There's just a black cable coming out of the wall, It is running from a switch above the counter top on the wall behind the sink. How do I wire this so that I can install a new outlet for the dishwasher and the switch will kill the disposal but not the dishwasher? Am I just better off leaving the disposal alone and run a new cable for the dishwasher up from a different power source? I know The Dishwasher is SUPPOSED to be on it's own circuit but I may not be able to do that.
Ron6519 10-03-2011 09:52 PM
Wire it correctly or don't put in the dishwasher.
SD515 10-03-2011 10:45 PM
There’s always a way to get something done. If the cable going to the disposal only has black, white, ground, you won’t be able to use that cable as is anyways. You’ll have to pull a new cable. Might as well consider taking a new cable right to the breaker panel.
CoconutPete 10-04-2011 08:24 AM
Has "new cable" written all over it.
It doesn't say where you live, but where I live - even if ALL the wiring is brand new, the only way they can share a circuit is if they both have plugs and are plugged into an outlet wired under the sink.
oh'mike 10-04-2011 09:14 AM
Not sure about your area but code here calls for a dedicated circuit for a dishwasher----
Ron6519 10-04-2011 09:47 AM
The instructions I've read that come with the units, say it needs a dedicated circuit.
