Dishwasher/stove No Power - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 10:48 AM   #1
Rewards Points: 14
Dishwasher/stove no power
Earlier this morning I started my dishwasher like normal. It filled up and went to cycle on and cut off. There was no power to it at all. I ended up going through all of the switches in the electrical panel and nothing was wrong. No breakers were off, nothing....
After checking the electrical sockets on the wall in the kitchen, everything works fine. The only two things that do not work is the dishwasher and stove. They both have no power.
What would cause that and how would I go about fixing it?
marchvet is offline   Reply With Quote
Old 06-19-2011, 10:54 AM   #2
I=E/R
a7ecorsair's Avatar
Did you reset the breaker or just look at them? Are the breakers labeled at to the circuit they protect? Can we assume the stove is gas and only needs 120 volts for the panel etc.?
a7ecorsair is offline   Reply With Quote
Old 06-19-2011, 04:02 PM   #3
" Euro " electrician
frenchelectrican's Avatar
This is a little odd conferation however I am thinking you may have a hidden GFCI or loose connection at one of the receptale.
So slide the stove out and see what kind of receptale you have there behind otherwise you will have to go in the basement { if you have it }or crawlspace and look at the junction box if there and look for loose connection.
Merci,
Marc
Old 06-19-2011, 05:56 PM   #4
Rewards Points: 6,652
First, is the stove electric or gas. If electric, possible you lost one leg. If gas, could be on the same circuit as the dishwasher, which it shouldn't, but weirder things have happened when you let Bubba wire a home.
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 10:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 08:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
