Dishwasher Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 04:00 PM   #1
Rewards Points: 152
dishwasher question
I live in toronto, ontario Canada.
i want to install a dishwasher, but cant remember, do i run a 15 amp line for the dishwasher or a 20amp line for the dishwasher?
humberguy is offline   Reply With Quote
Old 09-27-2010, 04:58 PM   #2
#12 awg wire which is 20 amp
jddavis is offline   Reply With Quote
Old 09-27-2010, 04:59 PM   #3
Rewards Points: 558
Itís a 20 amp circuit. Check your breaker panel if you already have one. If not, you will have to install one.
epson is offline   Reply With Quote
Old 09-27-2010, 05:04 PM   #4
Dishwashers are better to be on a dedicated circuit, the only exception would be is to put a disposal on that same circuit and thats because the two appliances dont usually run at the same time.
Old 09-27-2010, 05:14 PM   #5
Electrician
Rewards Points: 794
Check the data plate but you should be fine with #14 on a 15A circuit. 20A circuits are not used nearly as much in Canada as they are in the USA.
darren is offline   Reply With Quote
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
Installing a Dishwasher in a raised house from scratch cpshockl Plumbing 4 05-19-2010 05:43 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
Dishwasher Drain Question kypper Plumbing 2 01-15-2007 11:39 PM
