10-05-2012, 05:27 PM
#1
Bruce
Dishwasher install
We're replacing our cabinets, and getting a new dishwasher. Cabinets aren't here yet, but I'm starting to plan for appliance installation. The Bosch dishwasher we bought ( http://www.bosch-home.com/us/SHX55RL5UC.html?a=b) has instructions for hard-wiring, although it says it can also be modified for plug-in connection.
The instructions just show the romex left bare (no conduit) running from the back of the wall under the dishwasher to the front connections. Is this really okay?!? Would it be better to purchase the power cord for it, and set it up that way?
My concern about this is knowing where to place the outlet so that it won't interfere with the dishwasher when I push it back into place.
Any thoughts?
Thanks!
Reason: spelling goof - typing too quick
10-05-2012, 06:05 PM
#2
Dishwasher install
You are fine just running a piece of romex out of the wall near the bottom. Leave a good 4' coiled up for now and cut it to length after the dishwasher is set and you are ready to tie it in.
10-05-2012, 07:41 PM
#3
A "Handy Husband"
Dishwasher install
Not true in many locations. Often you need to provide a disconnect. This can be a wall mounted switch or a plug and receptacle. Personally I like to put the receptacle in the adjacent sink base cabinet and install a cord/plug on the DW.
Coastal South Carolina
10-05-2012, 07:59 PM
#4
Dishwasher install
It's true as far as the NEC. If a certain location has a different amendment, then that is a different story. Kinda like the way you can't use romex in Chicago.
10-05-2012, 08:05 PM
#5
Dishwasher install
Although plenty of people do it with direction connection as stated in the manual, Bosch makes it very easy to hookup to a power cord.
So when I installed my Bosch (SHX45P06UC) dishwasher, I used an universal power cord kit to make my dishwasher a plugin unit which made it easier to remove for maintenance/troubleshooting/upgrades.
The 3 prong power cord has thicker sheathing and more flexible. In addition, 6' cord length gave me plenty of space maneuver the unit for maintenance/troubleshooting/upgrades.
One thing to keep in mind is that I haven't seen these cords with flat plug heads so I installed a recessed receptacle box. I could have installed a receptacle box under my sink but with water filters, multiple shutoffs, etc., I just did not want to chance it being exposed to water leaks.
You may want contact your inspector to see what method is acceptable for your town.
Good luck
10-05-2012, 08:53 PM
#6
DIY Enthusiast
Dishwasher install
If it's a dedicated line from the Panel wouldn't the breaker serve as the disconnect?
10-05-2012, 09:04 PM
#7
Dishwasher install
so what do they use in Chicago, BX? Do you know if there is a particular logic behind that decision (i.e. pests, etc.)
10-05-2012, 09:31 PM
#8
A "Handy Husband"
Dishwasher install
A disconnect has to be in sight of the appliance. Seldom is the panel close enough to the kitchen to meet that requiement.
10-05-2012, 09:33 PM
#9
Pure Genius
Dishwasher install
But a breaker lock takes care of this
10-06-2012, 07:02 AM
#10
A "Handy Husband"
Dishwasher install
Only if you can see it from the dish washer.
10-06-2012, 07:12 AM
#11
Licensed Electrician
Dishwasher install
Not true, a breaker lock is acceptable if out of sight. That is the point. You can't see the breaker, so you lock it to keep it turned off instead of visually monitoring it.
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
10-06-2012, 07:41 AM
#12
A "Handy Husband"
Dishwasher install
I misread your post, I thought it said breaker box (instead of lock). Certainly a breaker lock accomplishes the requirement.
10-06-2012, 08:32 AM
#13
Dishwasher install
I believe it is because of vermin chewing on the wires. Not in Chicago, but I once owned a house where all the wiring was in metal conduit.
The Following User Says Thank You to md2lgyk For This Useful Post:
10-06-2012, 08:35 AM
#14
Dishwasher install
The more common theory is that this is a union code. If you are forced to use conduit, that rules out 95% of homeowners and unqualified handymen doing electrical work.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
10-06-2012, 01:14 PM
#15
Licensed electrician
Dishwasher install
Reason: correction
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
