Dishwasher Install - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 06:12 AM   #31
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Originally Posted by mickey cassiba View Post
all ceiling fixtures(lights, and fans are on this single breaker. Sounds like a hack job I know, but that is how the thing was built. 1968 Amherst MH. Still has the factory inspection(QC) stickers on the Breaker cover.
This is a serious code violation and dangerous situation. General purpose lighting and receptacle circuits are limited to 20 amp maximum. Additionally the wiring is to small for that breaker; #14 is limited to 15 amps, #12 is limited to 20 amps.
I doubt even in 1968 a mobile home builder would have used a 30 amp breaker for that circuit.. Sounds like some one changed it later on. Maybe because the breaker was bad or more likely it was tripping due to overload.
That condition needs to be corrected
Coastal South Carolina
Old 09-19-2011, 06:23 AM   #32
just a tool guy
mickey cassiba's Avatar
All wiring I have found in the MH is 12G...Would replacing the 30 with a 20 work?We can afford a new breaker...a rewire is financially out of the question. Alternately, I could break the overhead circuit into two or more 'zones, I'll still have 3 empty slots in the box, after the DW install. (and can a fixture bok be used as a JB as long as fill is not exceeded?)
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 09-19-2011, 07:00 AM   #33
Lic Elect/Inspector/CPO
Change the 30 amp cb to a 20. Than see if everything works without tripping breaker. It is possible the 30 was put in because it was tripping the 20. If so than splitting the circuits would be a good way to go.
NJMarine is offline   Reply With Quote
Old 09-19-2011, 07:21 AM   #34
A "Handy Husband"
rjniles's Avatar
+1, that is the way to go.
Yes using the fixture as a jb is fine, as long as you keep wire fills in mind.
Old 09-19-2011, 07:30 AM   #35
Code05's Avatar
Rewards Points: 1,104
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
mickey cassiba (09-19-2011)
Old 09-19-2011, 03:11 PM   #36
just a tool guy
Last question...I promiseIf I am to use an appliance cord, to make the hook up, is there a single outlet 120V receptacle available(Neighbor's a little old), and I don't want her plugging another appliance into the box. All I can seem to find are duplex receptacles. I know I could use a 240V receptacle(the single type) but that might mislead anyone that follows my work. Or do I glue a 'kid safe" into the second receptacle?
Mickey
Old 09-19-2011, 03:16 PM   #37
Rewards Points: 6,652
I would just use a standard gfci for the dishwasher. And just place a kid-safe into the outlet, but do not glue it in. That way, if you ever have to work on it, and need a place for a drop light, it is right there.
Old 09-19-2011, 03:20 PM   #38
A "Handy Husband"
rjniles's Avatar
As long as the receptacle is behind the DW a duplex is fine. If you want a single 20 amp receptacle you need a NEMA 5-20R. Probably will not find at a big box but any electrical supply house will have it.
Old 09-19-2011, 03:25 PM   #39
just a tool guy
Thank you all...hiding the receptacle will work...Nema type is out of budget....used a lot of them in the factories, and they're not cheap, err inexpensive.
Hi Ho, it's off to work I go.
Mickey
Old 09-19-2011, 06:43 PM   #40
Code05's Avatar
NEMA type is a configuration, not a grade or brand.
gregzoll (09-19-2011)
Old 09-20-2011, 05:17 AM   #41
just a tool guy
I know...but thanks just the same.
Mickey
Old 09-20-2011, 06:56 AM   #42
NEMA 5-20R are in big box stores. The lst one I bought cost about 5.00.
Using a duplex is fine and is less expensive.
dishwasher install - replacing copper feh Plumbing 7 03-21-2012 03:12 PM
New dishwasher install -- plumbing help kb01 Plumbing 3 04-23-2011 11:51 AM
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 09:59 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 01:05 PM
