Dishwasher Install - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 07:41 AM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by mickey cassiba View Post
plenty of room in the box...and only 65 amps out of 100 A service in use. I feel safe there.
What do you mean by this? Where are you getting this 65A number from?
Is it safe to have a 'plastic' cord under a movable appliance
Absolutely. A standard appliance cord on a dryer is very common.
Old 09-18-2011, 07:55 AM   #17
just a tool guy
mickey cassiba's Avatar
I added the marked breakers already in the box... 1 30A 1 20A and 1 15A. is that not correct?
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 09-18-2011, 08:06 AM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Speedy,
I think you meant dishwasher not a dryer.
Mickey C,
No you do not add up the up the installed breakers. Are you saying there are only 3 breakers in the panel (30,20,15)? This must be a sub panel and not the main panel for the dwelling (or at least I hope so). Identify the main panel and determine the amperage of the breaker feeding this sub panel. If is 50 amps or more you should be OK adding a 15 amp circuit to the sub.
Coastal South Carolina
Old 09-18-2011, 08:15 AM   #19
just a tool guy
Originally Posted by rjniles View Post
Speedy,
Mickey C,
This is the main panel for the trailer...has a 100 A main breaker. There is a second box on the service pole with 220V and a 100A main which services the HVAC, and utility shed(washroom). The boxes seem independent of each other...I can turn off the outside main, and house is unaffected...and vise versa.The meter base still has the POCO seal on it, so I have to assume(yeah, I know about the ASSUME rule) that it is an inspected and approved installation. One cable passes through the outside box with no connections and feeds the interior panel. the other feeds the three breakers in the outside box. Meter base is labled 200A
Mickey
Old 09-18-2011, 08:44 AM   #20
A "Handy Husband"
rjniles's Avatar
OK, now I get the picture. You should be fine to add a 15 amp circuit to that 100 amp panel. When you open the panel to make connections, note if the neutrals and grounds are on separate bars. If the are separated, make sure you terminate your new circuit the same way.
The Following User Says Thank You to rjniles For This Useful Post:
mickey cassiba (09-18-2011)
Old 09-18-2011, 09:36 AM   #21
Rewards Points: 6,652
When I had to run a circuit for the electric water heater in the 1960's trailer I owned in the early 90's, I ran UF under the trailer. I ended up using the structerial members underneath to support the run. You can do the same with this run, but if it was me, I would use conduit, so it is easier to upgrade later if needed.
You could still use clamping brackets to hold it against the underneath of the manufactured home.
Old 09-18-2011, 10:51 AM   #22
just a tool guy
That was the original plan...pretty cramped under there though. several corners to turn, be a pretty tough pull for these old shoulders. I've been rewiring my own place...upgrading from a 60 amp fuse panel to a 100 A breaker system All of the runs are outside in pvc. Looks like hell, but it works...and I can make the pulls witha a small hand winch
Mickey
Old 09-18-2011, 10:56 AM   #23
Code05's Avatar
Rewards Points: 1,104
Actually that is a problem. The panel outside is supposed to turn off the panel inside. Just letting you know.
Code05 is offline   Reply With Quote
Old 09-18-2011, 11:04 AM   #24
just a tool guy
There is a knife switch (in a weatherproof enclosure) between the meter and the box. Antiquated system I know, but all the contacts in the knife switch are bright and shiny, no trace of burning. They are two separate circuits after the knife switch.
Mickey
Old 09-18-2011, 11:18 AM   #25
Code05's Avatar
Ah, the knife switch kills power to both panels. That is fine.
Old 09-18-2011, 11:23 AM   #26
just a tool guy
Yes sir...meter feeds the knife switch, and disconnects both hot and neutral. Had this not been the case, I'd have called in a pro. I may be old, but I ain't stupid.
Mickey
Old 09-19-2011, 12:18 AM   #27
" Euro " electrician
frenchelectrican's Avatar
Just a single hot conductor et netural ?? or both hot conductor with netural being disconnect at the same time ??
Just a little more clear details on this.
It wil be nice if we did see the photo of it.
The only item I have see it once before in state side when someone did actually use the three phase disconnect switch as main service point somehow it did pass the code due both hot conductor et netural at the same time { the inspector did not like it too much but it was stated in the NEC code anyway }
Merci,
Marc
Old 09-19-2011, 05:37 AM   #28
just a tool guy
Merci,
Marc
Sorry Marc...don't own a digital camera. Meant to say that the switch is a three conductor switch, both hots(2), and neuetral are disconnected when the switch is opened. the service is completely disabledwhen the switch is open. This park was wired in the latew '40s, and as far as I can tell, the only upgrades have been transformer replacements as needed over the years. The ground cable is the only thing that is not switched, which is, as I understand it, proper. Only one hot leg goes into the dwelling...no 240 present inside. The utility shed box has the two hot, and neutral, driving the HVAC, and an electric dryer. Really quite primitive. My house has a 120 feed only.my disconnect has only two wires running through it. When I finish my upgrade that will be changed, as I require 240 for some of my tools. That work will be performed by a licensed pro...as a new meter and base will be required. Sorry for the confusion.
Mickey
Old 09-19-2011, 05:53 AM   #29
A "Handy Husband"
rjniles's Avatar
You said that inside 100 amp panel has a 30 amp breaker. If you do not have 240 in the panel, what is that breaker used for?
Old 09-19-2011, 05:58 AM   #30
just a tool guy
all ceiling fixtures(lights, and fans are on this single breaker. Sounds like a hack juob I know, but that is how the thing was built. 1968 Amherst MH. Still has the factory inspection(QC) stickers on the Breaker cover.
Mickey
dishwasher install - replacing copper feh Plumbing 7 03-21-2012 03:12 PM
New dishwasher install -- plumbing help kb01 Plumbing 3 04-23-2011 11:51 AM
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 09:59 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 01:05 PM
