-   -   dishwasher electrical wire (http://www.diychatroom.com/f18/dishwasher-electrical-wire-1287/)
feb 11-11-2005 08:52 AM
I bought a new dishwasher and ofcourse the electrical wire did not come with it. I went to lowes and bought an electrical wire for home appliances. The wire has no white and black wires - - only two blacks and a green. How do I know which wire to connect to the black and which to the white?
FEB
'Andyman 11-11-2005 09:44 AM
Dishwasher wire
Feb,
The wire you bought will work providing it is the right gauge. However, I would go and buy some NMD7-2 12 gauge (black, white and bare ground) even it it were just to conform to code.
feb 11-11-2005 10:44 AM
dishwasher wire
I don't have it in front of me but I think it is a 15 amp 12ga for appliance replacement. One of the wire is rough and one is smooth.
MinConst 11-11-2005 12:23 PM
feb has a good point. Wire is generally marked in some way to be able to tell it apart even if the insulation is the same color. A stripe, rouch and smooth slight color change in the wire itself. Something. Look closely. And as 'Andy said be sure the sire is the right guage for your appliance.
jbfan 11-11-2005 12:29 PM
Does this wire come with a plug? Did you have a dishwasher before? If you had one before, the wire should still be there. If so, then you just connect the wires to the junction box in front of the dishwasher. If you did not have one before, then you will need a new circuit from your panel to hook up the dishwasher. It sounds like the cord you have is a replacement cord.
feb 11-11-2005 01:41 PM
I gave my old dishwasher to my son. I let him have it with all the hookups - wire included. the new wire has a plug as did the old one. It is not hardwired, it is a plugin to the wall.
jbfan 11-11-2005 01:43 PM
Does the plug match the outlet? One of the black wires should have a stripe on it. Are you located in the US?
jbfan 11-11-2005 02:20 PM
After rereading your post and looking at lowes I see what you may have purchased. If it is like you say, one side smooth and one side ribbed, then the ribbed side will go to the white wire, and the smooth side will go to the black wire The cord is described as being only 3 feet long, and is used for a disposal. Is this the cord youo bought?
feb 11-11-2005 03:28 PM
I saw what you were looking at and mine looks to be the same ( I am not at home at the moment) except that mine is 6' long. The guy in the appliance dept told me that was the right cord and it didn't matter which wire went to the black (because it is alternating current:confused: )as long as the ground was hooked up. Is that correct?
feb
K2eoj 11-11-2005 03:54 PM
feb
No. Go smack that guy.
jbfan 11-11-2005 04:33 PM
I agree with hammer... Go slap the guy. If you listen to him, you can get yourself hurt!!!!
feb 11-18-2005 03:15 PM
dishwasher cord
Ok, the cord I bought for the dishwasher is as follows:
13A
125V
1625W
This cord is about 3' short because with the new cabinets, the dishwasher had to be moved over 2ft. I bought an extension cord with the following:
15A
125V
1875W
Is this ok to run it like that. I can't find a replacement cord that is the length I need. I would have to buy an extension cord and cut it the length I need.
Thanks,
Feb.
Mike Swearingen 11-19-2005 10:13 AM
Do NOT use an extension cord.
A dishwasher requires a dedicated circuit. Codes usually require a 15 amp breaker with 14/2-with-ground wiring, but I always recommend going with a 20 amp circuit and 12/2 in case anyone ever wanted to install a heavy-duty dw, if anyone is wiring from scratch.
As you've already been advised, if it's on a 15 amp breaker, get either an adequate length of at least 14/2wg or better yet, 12/2wg (black=hot, white=neutral, bare/green=ground) and wire it properly with a solid wire from the dw to the plug.
Good Luck!
Mike
shaneonl 04-10-2008 02:31 PM
can someone confirm the ribbed side of the appliance cord goes to the white wire
micromind 04-10-2008 07:54 PM
On any flat cord, 2 or 3 wire, the ribbed side is always the neutral.
On a recpacle, the larger slot is always neutral. If it's installed with the ground pin down, the neutral is on the left. Ground up, it's on the right. Now, hold the cord like it's about to be plugged in, you'll notice the ribbed side is on the neutral side.
On a 2 wire cord, you'll notice the ribbed side is on same side as the thicker prong. It can only be inserted into a recpacle one way; with the ribbed side in the neutral slot.
Rob
