Old 03-28-2012, 02:34 PM   #1
Dishwasher Electrical Connections
Hi. I purchased a used GE 715 potscrubber dishwasher and just completed the electrical hook-up. I'd like to get a confirmation that I have done it correctly before I plug it in. I purchased a 4ft long dishwasher power cable from home depot. The end wires were Green (ground), White (neutral), Black (hot). The dishwasher had the same wires exposed. I nutted together the white to white and black to black. However, I also nutted together the green to green. I know some dishwashers have you attach the power cable's ground to a grounding screw inside of the dishwashers electrical box, but this one had a green cable coming in that was coming from a grounding screw on the motor, which split from there to a screw on the frame.
I just want to make sure connecting the ground this way, together, was ok. Thanks for any help/confirmation!
rathrboutside is offline   Reply With Quote
Old 03-28-2012, 02:36 PM   #2
Licensed Electrician
k_buz's Avatar
Seems good to go.
The Following User Says Thank You to k_buz For This Useful Post:
rathrboutside (03-28-2012)
Tags
dishwasher hookup, dishwasher wiring, electical, electrical wiring, ground wire
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 10:19 AM
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 10:59 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Dishwasher installation Andy Griffith General Discussion 3 03-02-2009 07:06 AM
